4in. downpipe
Old 04-03-2006, 02:55 PM
Boosted12's Avatar
4in. downpipe
hey, i was wondering if a 4 inch downpipe would really give me faster spool and lower EGTs? Is it worth $350, or this one
http://cgi.ebay.com/ebaymotors/4-inc...spagenameZWDVW
Can you do something to your stock injectors to make them work like 330s or 370s??
Also, i just bought a pyrometer off ebay and should be gettin it in about 2/3 days
how bout this thing, does it do anything?
http://cgi.ebay.com/ebaymotors/Dodge...QQcmdZViewItem
Old 04-03-2006, 05:22 PM
Mike D's Avatar
I got a downpipe for $180. Check High Tech Turbo.
Old 04-03-2006, 05:25 PM
Racer9's Avatar
http://www.horsepowerupgrades.com/products.cfm SS $151
Aluminized $121
Old 04-03-2006, 05:30 PM
isissound's Avatar
is the cooleeze mega mouth worth it???
Old 04-03-2006, 06:53 PM
Boosted12's Avatar
so is it worth buying a downpipe? where are them Htturbo downpipes? link?
the hp upgrade one looks pretty good, did it give you very good power, nice increase in power?
Old 04-03-2006, 07:00 PM
marine4life's Avatar
yes, a bigger downpipe will spool the turbo quicker letting free flow exhaust which in turns allows more air to be brought in. More air, added with more fuel, equals more power. that boost elbow you linked to will block off the wastegate on your turbo. this stops the waste gate from dumping boost past 18-21 psi. with the stock turbo you should be able to safely make power up to 36 psi. after this you only make hot air which will decrease the efficiency of the turbo and plus the risk of overspooling is considerately more. overspooling a turbo is one of the worst sounds you could ever hear. it makes you cringe. not that i've done it though
Old 04-04-2006, 01:19 PM
Boosted12's Avatar
so will i be able to feel a difference with a bigger downpipe?
Old 04-04-2006, 01:22 PM
P.J
P.J's Avatar
Do a search, there is another thread already discussing this. The jury is still out I believe.
Old 04-04-2006, 01:24 PM
P.J
P.J's Avatar
NO.
Not with an entirely new exhaust system either in my opinion.
Old 04-04-2006, 02:01 PM
Boosted12's Avatar
ok, i think that i am just goin to cut my cat out an put a air cleaner on it
Old 04-04-2006, 02:27 PM
Boosted12's Avatar
what is like a 3kg gov. spring? will give me a big increase in performance?
Old 04-04-2006, 02:40 PM
P.J
P.J's Avatar
Not being smart, but you should try to use the search feature, it's your friend!
There is hours upon hours of reading here, 99 times out of 100 someone else has been in your shoes before. It's just a suggestion, this way if you read up on soething you were going to ask about and still don't understand, atleast people's responses will make better sense to you.
Old 04-04-2006, 05:48 PM
MNorby's Avatar
I only had to give $63 for my 4" DP from my local exhaust shop... at cost. I put on the 5" pipe and feel like i lost a little HP but I can hardly get it over 1000* on the pyro... so sweeet!!! I need to slide my #100 a little to make up for it.
Old 04-04-2006, 05:52 PM
Racer9's Avatar
Do you happen to remember the part# and brand of that $63 downpipe?
97catintenn
07-12-2009 05:33 PM
DU.DP.
06-13-2009 07:46 AM
streetsmoker
19
02-25-2007 08:58 PM
scarecrow
10-03-2004 11:00 AM
cwbronc
12-17-2003 01:23 AM
Quick Reply: 4in. downpipe
