48RE TransGo Shift Kit
Old 01-08-2007, 04:24 PM
shambo's Avatar
I have a question to those who have installed a shift kit or modified valve body into there 48RE.
I installed one this weekend in my truck! I seems to be working Awsome. Now my question is now that I have it installed my truck Smokes more out of the Exhaust. is this because more power is being transfered to the wheels therefore more load is being placed upon the engine? What are thoughts on this!!
Old 01-08-2007, 04:50 PM
acook's Avatar
Should be i wouldnt worry about it.
Old 01-08-2007, 06:50 PM
dieselram_04's Avatar
Yes the increase in smoke is caused from the additional load placed on the engine. now go out and have some fun!
Old 01-08-2007, 06:59 PM
shambo's Avatar
I can't wait to go to the track and see what changes it made at the track?
Old 01-08-2007, 08:41 PM
kev94mx's Avatar
How and where did help in the tranny?
Old 01-08-2007, 10:39 PM
Townsend600's Avatar
What is a shift kit? What does it do?
Old 01-08-2007, 11:05 PM
rfinn04's Avatar
shambo, please feel us in on what kind of differences your seeing with the transgo kit, I have one that will be here on thursday and cant wait to get it in and try it out.
Old 01-09-2007, 12:24 AM
morkable's Avatar
A shift kit will do a couple of things, 1) it will increase presures, making shifting firmer 2) it will change shift points. What it wont do is make your tranny stronger. You need to get a new tourque converter and valve body for that, and if you do any amount of racing you should have a full built race tranny (billet inputs and outputs etc) Also you should pay attention to your flex plate (ask 973604x4)
Kevin
Old 01-09-2007, 12:38 AM
Syndicate's Avatar
I understand how by upgrading the converter your upgrading to a stronger part but how is an aftermarket valve body stronger than the factory? Does it not primarily to the same things a shift kit does?
Old 01-09-2007, 12:42 AM
morkable's Avatar
If the valve body is properly done it will be upgraded to both provide more pressure, and to be able to handle more pressure (servo's etc) Im not a full out tranny tech but I know the basics
Kevin
Old 01-09-2007, 12:48 AM
desertram800's Avatar
Hey Shambo, I've installed a shift kit on a 1966 torqueflite 727 and it was a major PITA. I had to take apart the valve body, swap parts, drill channels and grind parts down, and I had a couple of the little steel ***** fall out so I had to find them and try to figure out where they went. Is this similar to the 48re kit? Can you please give a brief rundown of the process? Thanks!
Old 01-09-2007, 12:50 AM
morkable's Avatar
It will be very similar desertram. The 48re is basically a 727 updated with electronics and a overdrive on the tailshaft
Kevin
Syndicate's Avatar
ok I was just wondering if there was something i wasnt aware of. i was planning on installing the DTT billet servo and accumulator with the SK48Re kit. Funny thing is they are worth 2x what the kit is.
Old 01-09-2007, 01:24 AM
BigDave12768's Avatar
So what you are saying is... That after you installed your shift kit. Your tranny had no *****?
Old 01-09-2007, 02:01 AM
Syndicate's Avatar
Im hoping to get mine done soon after I get back from the concrete show in vegas at the end of the month. That is if I dont lose/spend to much down there.
Quick Reply: 48RE TransGo Shift Kit
