48re questions
Old Mar 15, 2009 | 06:59 PM
ol dodge codger's Avatar
48re questions
anyone know what controls tc lock up? Mine wants to lock up immediately after going into overdrive. All other tc lock ups are normal 1-2-3.
2003 ram 3500 drw h.o. eng
It has also developed a hunt between 1-2 with light throttle
clean fluid & band adjustment
Old Mar 15, 2009 | 07:23 PM
rmaynard's Avatar
Trans Hunt Light Throttle
In regards to part of your question ,I have an 05 3500 and the hunt turned out to be the governor pressure solenoid in the tranny valve body. There was a tsb on mine. Once this was changed, no more trans hunt. Roger M.
Old Mar 16, 2009 | 08:41 AM
no_6_oh_no's Avatar
Lockup is controlled by the ECU. Locking up immediately after goig to OD is normal. Lockup strategy is much more aggressive in TH.
The shift hunt is a pretty common problem on these units. The governor solenoid and transducer is the usual culprit. Change both when it is done. There is a TSB for this so if you are in warranty and complain loud enough you may get it done for free.
westport
May 12, 2005 05:24 PM
Bluedeviltorque
Apr 5, 2005 10:07 AM
wizkid
17
Jul 2, 2004 01:49 PM
DomVic
Aug 27, 2003 01:40 PM
GO 4LO
21
Jul 29, 2003 05:28 PM
