48re problems????
Old Oct 19, 2004 | 06:15 PM
Don-T's Avatar
48re problems????
The torque converter has been slipping and chattering for a while now but I could work around that. I have been planning on replacing the converter and trans with ATS parts. Now a new problem has come up that may require me to get the ATS stuff now. When I start the engine and wait for oil pressure to build up and put the trans in reverse it acts normal. When I put the trans in drive the engine stalls. It feels like the torque converter is trying to lock up when I put it in drive. This happens about 50 percent of the time. If I can get the trans to go into drive and not stall the engine, it is fine until the next time I start up. It seems to only do this the first the first time I put the trans in drive after a start-up. After it goes into gear once without stalling it is OK until the next start-up. Could it be the converter and why would it happen? There are no codes set.
Old Oct 19, 2004 | 06:21 PM
Dodgezilla's Avatar
Sounds like maybe a bad lock-up solonoid......
DJ Turbo.
Oct 13, 2011 09:11 PM
rkelley
30
Mar 10, 2007 06:53 PM
belfert
25
Sep 14, 2004 05:50 PM
Chester
Aug 6, 2003 12:09 PM
