48RE performance advice
Old 01-05-2007, 11:41 AM
MrSlug's Avatar
Please forgive the noobness of this post.
In my 06 CTD with a 48RE, I have an Edge Juice with Attitude. When I want to pass slow moving objects on the freeway (lets say from a rolling 55mph) I set the Edge to 3 and mash on the gas.
The truck starts to build power up to 2500 rpms, then it sits there for about 1-2 seconds (like its staying in the lower gear for too long), then the tranny shifts and the truck starts to take off like a rocket.
Are there any tricks to coaxing the 48RE for better shift points with rolling take offs? I know in my old 89 crapstang GT, I had to manually shift the auto trans from 1 to 3 and back to 1 to get the car to launch right from a stop making it use 1 2 then 3. Otherwise the dang POS ford would go from 1 to 3.
Old 01-05-2007, 11:44 AM
morkable's Avatar
When I had the stock tranny, mine would do that too, what I did was just let up slightly on the pedal, just when it should shift, then it will shift then mash it again
Kevin
Old 01-05-2007, 01:30 PM
BigDave12768's Avatar
Hey I just got the Edge Attitude and I think your problem is the way you have it set up. Now I am no genius at this but I took my truck out on the highway last night and played with the settings. Go into the menu and select Juice config then Low Boost adj(enter) another screen pops up change the setting to 5 then hit enter again. Then you have to back out hitting the menu button. You will get more smoke out this option also
Old 01-05-2007, 04:00 PM
MrSlug's Avatar
Thanks for the advice but I have already setup the low boost adj as follows:
Stage 1 = 3
Stage 2 = 3
Stage 3 = 5
Stage 4 = 5
Stage 5 = 5
Still have the funky shift deal.
Old 01-05-2007, 04:38 PM
jwb600's Avatar
ive got an 06 with a bone stock tranny for the moment, I run a triple dog it is fast to downshift when I get on it. crusing around it shifts all over the place, on performance, it dont like like larry when he gets crazy at all
Old 01-05-2007, 05:33 PM
2-Stroke's Avatar
yea, like morkable said... i run CL exclusively now - just roll into it until you are on the brink of downshift then once you are past the kickdown point go WOT. Its all about learning your trucks habits
Undertaker
03-20-2010 06:33 AM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
JCLeary
01-22-2008 10:19 AM
Megaramasaur
10-24-2006 06:02 PM
bigman
07-25-2005 07:44 AM
Quick Reply: 48RE performance advice
