48re overdrive upgrade......
Old 08-04-2009, 11:21 AM
mykal41's Avatar
installed the suncoast master rebuild and all is well......untill the over drive. Stock has 5 clutches new has 6... do i need to machine the pressure plate or can i remove the waved snap ring for the extra clearance. I could also just install 5 like there was before. So many options what would you guys do?
Old 08-04-2009, 11:43 AM
RowJ's Avatar
Don't know exactly how to do it (mine was done by DTT installer), but the 6 clutch plates are worth having!
RJ
Old 08-04-2009, 11:51 AM
DTR Advertiser
Timinva's Avatar
You need to remove the wave ring, (keep the flat snap ring) and machine the reaction plate. Tim
Old 08-04-2009, 12:30 PM
RowJ's Avatar
Answer from "the man" himself!
Tim, which Flux injectors does it take (do you run) to get to 800+ hp w/ your setup?
And when are you moving to Texas.... We could sure use you!
RJ
Old 08-04-2009, 01:49 PM
DTR Advertiser
Timinva's Avatar
On my 06 we did 824hp on 3.3s, 875 on 4.3s. On my 04 555 never used smaller than a 4.3 and it did 868 on those. Tim
nvr-enuf
08-14-2007 12:58 PM
72demon440
04-27-2007 10:45 PM
Offroad9
33
12-06-2006 09:59 PM
eldorado
11-17-2005 03:57 PM
scott hall
47
07-08-2005 04:41 PM
Quick Reply: 48re overdrive upgrade......
