47re...similar transmission to what
The reason I ask is im looking for a good overhaul manual for the 47re and i can seem to find anything. I find a lot of the other chrysler transmission manuals, just not the 47re. I have a factory sevice manual and it seems to go through more diagnostics then teardown/overhaul. Is the FSM the best manual or have you found other manuals to work from too?
Thanks,
Dave
Thanks,
Dave
The RH has a mechanical governor, the RE is computer controlled pressure, the late 48RE's are computer controlled - other than that, the valve body is different, with solenoids, but the mechanical internals are near identical - use the 48RE stuff in the 47's for increased strength - the A500\518\618 pretty much covers it
HorseHauler
18
10-22-2004 04:14 AM
NJMurvin
03-06-2004 08:14 PM
BigBlue
07-17-2003 12:56 PM
