47re fluid change or flush
Old 04-29-2006, 11:42 AM
MARKY MARK's Avatar
Went to get atf+3 for my fluid change today but all I could find was atf+4. It says on the bottle "replaces atf+3". So I picked up 8 quarts of the atf+4. Hopefully I made the right decision? Now, with what I assume is atf+3 in my tranny now...should I just drop the pan and put in the atf+4 or should I drain the whole system to get a complete atf+4 change? I know I'll need more if I do the complete change. Something like 16 quarts?
Mark
Old 04-29-2006, 09:18 PM
MARKY MARK's Avatar
Anybody out there?
Old 04-30-2006, 06:04 AM
Rauschbo's Avatar
I purchased a VB from DTT, and they included a copy of the Chrysler recommendation to use +3 for all Chrysler transmissions; When I bought the 10 qts of fluid for the change, the guy at Schucks told me to get +4, and showed me the note on their computer saying that +4 superceded the +3 fluid. I'm holding off using this until I get in touch with DTT - sorry, I didn't help you, but I have the same question!
Bump?
Old 04-30-2006, 06:47 AM
P.J
P.J's Avatar
I think if I could use +3 (like in a DTT trans, or older 47RE's) I WOULD! The +4 is just too expensive. I paid $7.50 a quart last time i got it.
Old 04-30-2006, 08:03 AM
sadlerb_98's Avatar
You can use it
Marky Mark,
here is the TSB on the subject. It looks like you should be fine. I am sure someone else will chime in as well.
http://dodgeram.info/tsb/2004/21-004-04.htm
Bob
Old 04-30-2006, 09:47 AM
MARKY MARK's Avatar
Thanks for the replies. That TSB says that the +4 can be added to the +3 so I should be Ok.
Kragen had the Valvoline ATF+4 for $3.49 per quart and the +3 was the same price.
ultramag
04-26-2012 07:54 AM
smokinram99
06-06-2008 08:09 AM
THEDIESEL
47
08-10-2007 01:52 PM
boostjunkie1
12-28-2006 05:08 PM
LFD2037
11-08-2006 09:12 PM
Quick Reply: 47re fluid change or flush
