4 wheel low?
Old 05-09-2011, 07:53 PM
tom creek's Avatar
4 wheel low?
4 wheel low 3rd gear launch on dirt why would everything give up it felt like the truck was coasting.I rolled to a stop put it in 2wheel drive 3rd gear again truck lunched great with no problems.Is there something in the transfer case like a safe switch that kicks it out when you over rev it
Old 05-09-2011, 09:54 PM
Mr Jerry's Avatar
Two things come to mind,,,,(1) it wasnt all the way locked in to 4-wheel or
(2) some trucks dont like being thrashed on.
Old 05-09-2011, 11:50 PM
Administrator/Jarhead
madhat's Avatar
It may have jumped out of 4wd.
Old 05-10-2011, 12:12 AM
Nate-03 D's Avatar
Just curious here. What would warrant a "launch" in 3rd gear 4-lo? You can't go but about 5mph. Pulling a stump?
Is your t-case a manual or electric?
Old 05-10-2011, 06:30 AM
tom creek's Avatar
its electric,I am trying to figure out what gear to use for sled pulling.some say 3 low,some say 2 high.my first pull will be next month just trying to find out what gear to use.only thing i can figure is there must be some sensor that calls for the transfer case to kick out upon higher revs.if anyone knows if this is correct or is there another problem.
Old 05-10-2011, 08:05 AM
madhat's Avatar
What rear end gears?
I'll have to look later to see what the manual says. I think I have a electronic t case in my book...
Old 05-11-2011, 02:15 PM
tom creek's Avatar
just found out from dealer that it does have a speed limiter in the transfer case that causes this problem.I guess ill try 4 hi 2 gear. only thing is some say you can break stuff in high range.Or maybe that was duramax guys saying their stuff breaks in 4hi.
Old 05-12-2011, 07:37 AM
rockcrawler304's Avatar
Ask that dealer where the speed limiter is. I have the same t-case and have never had a problem. I think they looked up the wrong vehicle.
Old 05-13-2011, 06:46 PM
tom creek's Avatar
I think your right,I have talked to others that say it only has a motor my guess is the fork or a bearing i am going to another dealer Tuesday he said he would check the electrical system,motor.If all checks out good then its the transfer case ill keep you posted on what i find.What troubles me is i havnt put the truck in 4wheel drive more than 7maybe 8 times from the time i bought it.
rjm022
13
06-09-2023 06:34 PM
rbrettctd
04-23-2007 01:23 PM
Breck-Ram2500
06-02-2006 07:47 PM
spitzair
01-24-2006 03:42 PM
Quick Reply: 4 wheel low?
