4 inch lift?
Old 12-13-2004, 08:27 AM
Graphite600's Avatar
4 inch lift?
What affect will a 4 inch lift and 315's have on my mileage, and wear and tear on my truck, is it worth it?
Old 12-13-2004, 11:09 AM
cquestad's Avatar
Will lose 1-2 mpg depending on how you drive. Wear and Tear can be some or none depending on the lift and wheel selection...
In short...I love my set up.
Old 12-13-2004, 12:18 PM
Buckshotmckee's Avatar
One thing to keeps in mind is what kind of lift you put on, and what I mean is one that is half a** put together or a proper lift kit. Proper lift, longer trailing, control arms, longer pitman, sway bar relocating brackets, etc. etc. etc., ex. Superlift. Half a** would be just coil springs and blocks. As far as mileage and power goes, what gear ratio do you have? That will determine the power change.
Old 12-14-2004, 09:56 AM
WhiteSport600's Avatar
How do your Bilsteins ride? I got the Tuff Country shocks with my kit and they are VERY firm. I wish I could get back to a stock type ride. What length are they and model???
Old 12-15-2004, 10:33 AM
I have the 3.73 rear axle ratio, and am thinking about either a skyjacker 2.5 inch suspension lift, or the skyjacker 4.5 inch suspension lift kit, what do you guys think about these lifts, and do any of you have them, pics would be nice!
Right know I am thinking that the 2.5 inch lift will not even be really noticeable as far as height goes!
Old 12-15-2004, 11:52 AM
Patrolman808's Avatar
The 2.5" looks just like stock almost. You can't really tell it's lifted. It's like you see two stock trucks at the dealership, and one may be a tad higher from the factory than the other. Nothing stands out about it really. But you could clear 35's easily though.
Old 12-15-2004, 11:56 AM
cquestad's Avatar
Bilsteen 5100's for a 4-5" lift. Ride is far superior to the Tuff Shocks.
Old 12-15-2004, 03:53 PM
I think I'll go with the 4.5 inch kit from skyjacker, comes with replacement longer shocks, and rear add a leafs, is this kit any good? I know skyjacker has a great rep. I have one more ?, will I need any more accessories with this kit, like extended brake lines etc. I dont know much about lifts so fill me in.
THANKS,
RYan
Old 12-15-2004, 04:34 PM
It's a pretty easy bolt in kit. You shouldn't need anything else... BTW thanks cquestad, I'm looking into the Bilsteins...
Old 12-15-2004, 04:54 PM
Bilstein doesn't show any 5100's for anything more than a leveling kit! Where did you order your's from? Who do I call?
Old 12-15-2004, 06:13 PM
cquestad's Avatar
Call Jack It...they have them for a good price.
Old 12-15-2004, 06:22 PM
Jmac's Avatar
WhiteSport600,
Jack it's # is 1-801-974-7960. I delt with Tyler via e-mail. He was very helpfull.
BTW I love these shocks... I don't get knocked around anymore driving over dips and bumps in the road, soaks up the road nicely.
hope this helps.
Old 12-15-2004, 10:06 PM
mudturtle660's Avatar
you don't need a lift to clear 315's, all you need is a 2" leveling kit, i also added an add-a-leaf, this is a cheaper alternative to an expensive lift kit
Old 12-16-2004, 08:23 AM
taylorj's Avatar
WhiteSport600,
I have the bilstein 5100's on mine and they ride great, I got them from Jack-It as well. If I had known it would have ridden that much better with the bilsteins, I would have upgraded to the lift and shocks sooner.
Johnny
Old 12-16-2004, 09:36 AM
Thanks for the info guys, I'll give 'em a call.
hwebb
03-01-2010 12:42 PM
KKoteles
30
04-16-2008 11:07 PM
KKoteles
06-19-2007 06:06 PM
shaft
09-01-2003 03:37 PM
bdaniel
05-06-2003 04:43 PM
Quick Reply: 4 inch lift?
