4" exhaust? Will this help my turbo come to life sooner?
Old 11-09-2011, 09:39 PM
Weaverwelder's Avatar
If I put a 4" exhaust on my truck. Will that allow my turbo to wind up, produce more boost, at a lower RPM? Or do I need to turn up the fuel pressure? or both?
Old 11-09-2011, 09:46 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
it will help lower EGT's but I would not look for any kind of performance boost from it on it's own.
Old 11-09-2011, 10:07 PM
What are EGT's? And if the turbo is providing boost sooner than wouldn't that provide some kind of improvment?
Old 11-09-2011, 10:09 PM
seahawkdodge's Avatar
It will help a little bit if the engine is stock, but other than the turbo spooling a little bit sooner, you won't notice much. However, the benefits will be more apparent when you add other power goodies.
Old 11-09-2011, 10:13 PM
Pickin on the wrong admin...
Diesel Dave2's Avatar
EGT: Exhaust gas temperature
What exactly are the benefits of a 4" exhaust?
Old 11-09-2011, 10:18 PM
The biggest benefit is reducing the exhaust gas temperature, or EGT. Too high of an EGT, and pistons melt. The larger exhaust helps get the heat out of the cylinders faster.
Old 11-09-2011, 10:21 PM
Does that mean my engine will take longer to warn up? Also What would happen if I just increased overall boost. I have been told that the 12v stock engines can take it with out head upgrades.
Old 11-10-2011, 09:48 AM
13FOX's Avatar
More boost does not mean more power. You have to push more fuel and then you can see a rise in boost pressures above stock. Far as headgasket, I wouldn't push boost past 40 psi. Adding a 4" exhaust will help the engine breath better and lower EGt's as stated above. Search around this site and you will find a lot of the answers you are looking for.
Old 11-10-2011, 11:32 AM
infidel's Avatar
You'll find many questions answered here> http://dodgeram.org/support_pgs/diesel_ix.htm
Exekiel69
12-21-2010 08:28 PM
PEAKSTRYDE
10-11-2007 04:20 PM
BigBlue
41
04-24-2006 09:36 AM
jerky1280
12-20-2005 04:15 PM
60 Gunner
07-17-2003 10:25 PM
Quick Reply: 4" exhaust? Will this help my turbo come to life sooner?
