3rd gen turbo on a 12 valve?
Old 04-06-2009, 05:44 AM
kyle_truck_pull's Avatar
Question 3rd gen turbo on a 12 valve?
can you put a 3rd gen turbo on a 12 valve truck? it should work shouildnt it? I just got a 66 off a 3rd gen, and i want to put it on my 12 valve.
Old 04-06-2009, 03:21 PM
BLUEBURNER's Avatar
not to hi-jack, but im interested in this myself
Old 04-06-2009, 04:44 PM
stevenl's Avatar
im pretty sure youd have to reclock the trubo so the exhuast housing and the boot outlet are in the right position for a 12v motor. i think. dont quote me on this
Old 04-06-2009, 07:50 PM
im pretty suer all i have to do is spin the charger to where whe intake and exhuast will be in the right spot.
Old 04-06-2009, 08:13 PM
Matt_g's Avatar
you can. im currently doing this to my 12 valve now.
Old 04-06-2009, 08:59 PM
stevenl's Avatar
like i said haveing the exhast and outlet in the right spots. i have seen it done, but with like 4 silicon boots attached, can you say boost leak?
Old 04-06-2009, 09:00 PM
Registered user
Riflemanusmc's Avatar
BigBlue has one on his 2nd GEN. You can find a great writeup by him in the 3rd GEN Performance section.
Old 04-07-2009, 12:16 AM
Tate's Avatar
If you are putting a 3rd gen S300 on, you should be able to reclock the compressor housing to where the outlet faces in the right direction. But the discharge isn't as far away from the inlet as it is on the second gen, since we use the clamp on elbow. The stock 3rd gen turbos have the wastegate actuator attached to the compressor housing (like the later model HX/HY turbos), so thats why you would need to add extra piping to connect it, since it can't be easily reclocked.
Old 04-08-2009, 12:57 AM
Big Blue24's Avatar
Third gen turbos have a different compressor cover that like Tate said locates the cold pipe farther forward in the engine bay. The outlet does not drop down as far as the second gen turbo with clamped cast elbow so no matter what you do, you need like 2 45* silicone 3" elbows and short piece of 3" pipe.
Old 04-08-2009, 05:44 AM
ok, this will make sense once I start doing it. Im gonna start putting it on this friday.
Old 04-10-2009, 09:54 PM
I got the turbo on and the intake ran. it was hard but I got it. I used the stock 3inch down pipe elbow for the inlet on the intake for the intercooler. it looks good, the only problem im having now is for the oil feed line fittings.
anonymous_1
13
04-30-2020 04:29 PM
BRUISER
02-02-2015 11:25 AM
ImpulseHydro
05-29-2008 02:53 PM
1qckdodge
03-05-2007 09:53 AM
Quick Reply: 3rd gen turbo on a 12 valve?
