38.5" tires. Do I need a larger lift?
Old 05-03-2007, 07:51 PM
Captain's Avatar
I have the skyjacker 4.5" lift thats more or less 6" of lift. I have run 38.8x11x16's on the stock wheels and they fit just fine no rubbing. I want to run procomp xtreme AT 38.5x14.5x17 on H2 wheels. The actual width i think is 15.1 according to procomps website but dosent say on what wheel. Does anyone think this will fit? And if not will a 7" skyjacker type lift work? I'm thinking DC long arms, more rear blocks (im cheap and allready paid for the full skyjacker leaf packs once) and coils from some where. I can thandel the red ones for SJ and not paying to have there powder coat burned off and re done in black again.
Thanks all.
Old 05-03-2007, 07:56 PM
99globalwarmer's Avatar
i think it might work.
Old 05-03-2007, 08:20 PM
walkram42's Avatar
I got 38x15.50 on 16.5 wheels with the skyjacker 4.5 and a 2 inch body lift. No rubbing, but without the body lift I would be in trouble.
Old 05-03-2007, 09:06 PM
Captain's Avatar
Sounds like I need the 7" lift then.
Old 05-04-2007, 12:04 AM
walkram42's Avatar
That is what it sounds like, but I also have fender flares that is where the tires would rub on mine. If you don't have flares, try to find someone in your area with that size tires to see if they fit. Good Luck!
Old 05-04-2007, 08:34 AM
Captain's Avatar
Thats what I was hopeing to do but I doubt ill find anyone with a tire that size on the correct backspace wheel. Aftermarket wheels seem to stick out much farther then stock or H2 wheels.
Old 05-04-2007, 09:14 AM
Gotlift01's Avatar
You might end up rubbing your control arms at full turn with a tire that wide and not having much back spacing on the wheels.
~Nick
Old 05-05-2007, 04:26 PM
Captain's Avatar
if I put in 2" spacers on top of my coils, do you think I'd need longer controll arms?
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
sakisaki400
23
12-31-2006 10:17 PM
Scotty
04-01-2005 10:09 PM
needlern32724
05-01-2004 01:46 PM
Quick Reply: 38.5" tires. Do I need a larger lift?
