Will this be 325 H.P. ?
Old 02-24-2008, 04:48 PM
Dieselcamper's Avatar
Finally decided to go with some Mach 1.6 injectors to go with
my Smarty , 4" exhaust , AEM workhorse intake and southbend
OFE clutch. Will this put me at a "safe" 325 hp with stock turbo ?
Old 02-24-2008, 06:06 PM
hotdram's Avatar
I have that same setup (except the AEM, I have a BHAF).
Have not dynoe'd yet (just got the clutch installed in December). Everyone around here says that combo should be good for at least 350
The HO is 245 BHP (should dyno around 220 RWHP stock I think)
If I recall correctly, Don rates his injectors as HP increase seen at the rear wheels, and the 1.6's are 90 HP units. The Smarty is a 65 HP programmer. All that adds up to 375 HP, BUT if I remember correctly, the Smarty 65 HP gain doesn't occur at the peak of the curve. That is why 350 guestimate is probably reasonable.
~Rob
Old 02-24-2008, 06:12 PM
hotdram's Avatar
Forgot to mention, I am running a manual boost controller, and with the Smarty on S/W #7, I see about 36 lbs. of boost with my stock turbo, I believe that is just outside the upper end of the efficiency curve for the HX-35. However, 36 PSI is under what is deemed destructive to a stock head gasket.
~Rob
Old 02-24-2008, 06:58 PM
HOHN's Avatar
I'd expect an honest 335-345hp at the wheels.
325 is almost a given, unless the engine has something seriously wrong.
jmo
Old 02-24-2008, 07:14 PM
I have the boost elbow set at 32 psi . Engine has 88,000 miles
and is still in good condition. Just want another 50 hp over
the Rv275 injectors.
Old 02-24-2008, 07:27 PM
dzlfarmboy's Avatar
Should be around 360hp my partner did 340 with 1.2's and a smarty heres the thread http://www.competitiondiesel.com/for...ad.php?t=10045
Old 02-25-2008, 12:47 AM
Krob's Avatar
Hotdram i may be mistaken but i owuld be carful running over 35psi of boost i remeber reading that 35psi or greater could damage the the turbo which could damage your engine. just my .02
Old 02-25-2008, 12:18 PM
Big Blue24's Avatar
Yeah, mine has had spikes up to 43-45 psi, and it is the original turbo with 230K miles on it. These HX's are tough! I usually try to keep mine in the 30's, but the Adrenaline fuels so hard, the wastegate cannot keep it below 35.
Old 02-25-2008, 06:34 PM
rootremblay's Avatar
I ran my HX-35 at 48 lbs for 6 months then set it at 36 for another six months and with 170,000 when I took it off it was still good to go. Their tough little boogers just create alot of heat after IMHO 38 lbs
Old 02-25-2008, 10:59 PM
rebal's Avatar
catcher (smarty on #9) and 1.6s will push 38 psi floored at 32 psi i run 1250 egt at 2500rpm at lower rpms it runs cooler egts .the hx35 chocks and heats at higher rpms my toy hauler tips in at 16950lbs
Old 02-28-2008, 04:16 PM
The Guru
Mike Holmen's Avatar
My truck put down 320 with a set of 90rwhp and an edge ez box. I'm not sure what the smarty will give ya but its more than likely less than the ez. You will be fine with the stock turbo, I've ran 400rwhp with a stock turbo and the motor survived the abuse from my right. What kind of egt's and boost you seeing at wot? Just don't push the turbo above 37psi.
Dirk5.9
01-12-2011 02:45 PM
George&cheryl
57
02-15-2004 10:24 AM
drsmart
46
01-17-2004 08:10 AM
Mechanos
01-12-2004 03:16 PM
dodgeram
01-03-2004 07:45 AM
Quick Reply: Will this be 325 H.P. ?
