315's on a dully?
Old 05-20-2009, 08:08 AM
ram 2500's Avatar
315's on a dully?
My uncle has a 08 megga cab dully, and he is wondering if he can fit a set of 315/70/17 under it? can you guys post some picts if so?
Old 05-20-2009, 08:10 AM
cmac's Avatar
i believe you will need some spacers on the back wheels, otherwise the tires will rub together and ruin the tires.
Old 05-20-2009, 08:35 AM
TonyB's Avatar
I have 265's on mine. They fit ok and need to be at >65psi with a load on.
315's, I think would be a problem when loaded. As cmac said, you are likely to need spacers. Then you are limited to how thick spacer V. length of wheel stud.
Tony
Old 05-20-2009, 10:21 AM
mcolectd's Avatar
This one has 35s with spacers in the rear:
dieselJon
01-21-2008 06:30 PM
hydrive1953
11-08-2007 05:16 AM
smokey196240
02-06-2006 05:58 AM
SmokenRam
12-27-2005 06:45 PM
Quick Reply: 315's on a dully?
