PDA
View Full Version : 3.9 info???
wap
05-14-2008, 06:32 AM
I am (hopefully) gona be starting on a Jeep CJ project some time this summer. And along with the usual 1 ton runnin gear and such I am considering a motor swap. I was originally planning on a 6.0 chevy gas burner but if I could find some places willing to make upgraded parts, ie injectors and injection pump, I think I would like to have a 250-300hp diesel instead.
So, I am looking for info on swapping a 3.9 into a Jeep and also where to look for performance parts.
Oh and unless someone has a reason not to, I think I would like to use a mechanical 3.9, like the p pump 12vs. I just think it would be a lot simpler to instal and no electronics to short out in the water.
TIA
j-fox
05-14-2008, 08:07 AM
4btswaps.com
The most common pump on the 4bt is the rotary VE pump.
Some are inline p-7100.
Go to 4btswaps to find places to buy one, but those guys don't know alot about diesels. Well, some do.
The 4bt will torque like a big block and be as fuel efficient as a 4 cylinder!!!
Most of the time, you won't need to change injectors, as the pumps have enough adjustment.
But you want 300hp, that would require bigger injectors,turbo, intercooler.
wap
05-14-2008, 04:12 PM
Awsome, thanks for the info and the link.
I dont think I will go to the trouble for an intercooler. Just because this jeep, though street legal, will be mainly for off road. I probably wont drive it much more then 10 miles on the highway and it will spend most of its time off road, muddin or crawlin at low speeds.
And I kinda figured on usin a 03ish 5.9 turbo. I havent done much research yet (if you couldnt tell...) but its just a swap I was lookin at just cause it is differant and I would like to see a jeep blowin black smoke every now and then. Plus the torque and the fact that it will run at any angle.
