3.73 OR 4.10 How do I know?
Old 09-22-2009, 12:12 PM
huron52's Avatar
Is there an easy way to figure out which gear ratio I have in my truck VIN numbering?
I figure it has to be either a 3.73 or 4.10 At about 62mph the tach says 1900
Old 09-22-2009, 12:17 PM
pdogg's Avatar
I'm 3.73 for sure, stock tires, etc... here's my RPM's
45mph - 1400rpm
55mph - 1550rpm
60mph - 1700rpm
65mph - 1800rpm
70mph - 1950rpm
Old 09-22-2009, 12:20 PM
05HDRAM's Avatar
I am pretty sure it is on a sticker in the glovebox.
Old 09-22-2009, 12:54 PM
92'1stGen's Avatar
If you have a 6 speed then you have 3.73's, it's the only ratio available w/ the G56 in 06'. The G56 is naturally geared much, much lower than the previous manual offerings.
Old 09-22-2009, 01:15 PM
huron52's Avatar
Wow
Thanks for the quick response!!!
3.73 I'm good with that...
Side note
I suppose I should have said... the tires are 265/70/17
No sticker inside the glove box.. I guessing long gone.
Old 09-23-2009, 06:25 AM
dogger's Avatar
Axle ratio
One way to determine the axle ratio is to raise one rear wheel and with the tire valve stem pointed toward the ground and a mark on the driveshaft. Turn the wheel one complete revolution and count the number of times the driveshaft turns. More than 4 turns - 4.10; less than 4 turns - 3.73
Limited slip you while have to raise both rear tires.
L8r,........dogger
Old 09-23-2009, 11:26 AM
Undertaker's Avatar
There is a sticker in the glove box that will have that information. If not call a dodge dealer and give them the VIN.
Old 09-23-2009, 12:14 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Amazing how such a simple topic can bring out childish behavior in some people.
Old 09-23-2009, 02:00 PM
randallp84's Avatar
???? I don't think any of the posts exhibited childsih behavior, unless you deleted one...
Old 09-23-2009, 02:17 PM
Admin Team Leader
I didn't delete one....I deleted 10 of them
Old 09-23-2009, 02:23 PM
elirandolph's Avatar
WOW! Thats Crazy.
Old 09-23-2009, 03:02 PM
RiverRat2's Avatar
Thats what I'm thinking???????? LOLOL!!!!!!
Old 09-23-2009, 03:19 PM
Mlucas's Avatar
thankyou!
Old 09-23-2009, 05:11 PM
huron52's Avatar
Yes thank you!
Old 09-23-2009, 06:59 PM
Utundra's Avatar
I bought a Ford once that had 3.73s or 4.11s installed. I had no intention of towing and had them swap axles with a different truck on their lot for 3.55s. I doubt it was ever updated in Ford's database and certainly not any of the stickers on the truck. To be 100% certain count the revs like dogger writes.
Quick Reply: 3.73 OR 4.10 How do I know?
