2nd gen "INTAKE" manifold
Old 08-21-2009, 06:36 PM
Bswope's Avatar
I have a 2nd gen intake manifold and was wondering if anyone has any pics of there swap? I know some have it done and I have one and wann put it on but it looks like the angle on the 2nd gen intake is off and looks like the intake tube might not line up. Or am I just lookin at it wrong....
Old 08-21-2009, 06:55 PM
Pooter's Avatar
I havent put mine on yet, but it lines up just fine, theres enough give with the two boots on the IC to horn tube.
Old 08-21-2009, 06:59 PM
Bswope's Avatar
If I have time I might give it a whirl tomorrow!! If I do Ill get some pics and let ya know how it went!!
Anyone else that has already installed theirs?
Old 08-21-2009, 08:44 PM
Pooter's Avatar
Good deal!
Only thing holding me up is too much work, havent had time to swing by Cummins and pick up the $8 gasket so I can swap it out
Old 08-22-2009, 06:32 AM
Dodgezilla's Avatar
It's a very easy swap. Yes the angle is a bit different but it hooks together just fine. My stock gasket was very stuck to the grid heater so it took me about 20 minutes to scrape it all off. Luckily my intake came with the gasket also. Just make sure you have the longer bolts needed for the 2nd gen unit...
Old 08-22-2009, 09:05 AM
megacabdad's Avatar
What is the benefit of this swap?
Old 08-22-2009, 09:14 AM
ohyeahfriday's Avatar
The 2nd gen manifold has a better "design" and flows more air than the common rail one does. Relatively cheaper options than the $180+ for an aftermarket horn. Excellent option if you do not need auxiliary ports for spraying.
What years manifold are you guys putting on? Or is it any 2nd gen?
Old 08-22-2009, 09:27 AM
megacabdad's Avatar
Hmmm...
I'm going to have to "borrow" my buddies 2nd gen!
Old 08-22-2009, 11:32 AM
That is why I want to know years to use, my cousin has a '95 12 Valve he parted out, but IDK if the intake manifold willl work or not?!?
awaits the knowledgable chim in
Old 08-22-2009, 03:05 PM
Dodgezilla's Avatar
I believe it's pretty much any 2nd gen 24 valve truck. I have not heard of anyone using one from a 12 valver. Mine came from an 01 truck...
Old 08-22-2009, 04:00 PM
kuhkuhkyle's Avatar
12 valves use a twin port intake. thats why banks had that twin ram. it needs to be of a 24 valve 2nd gen.
Old 08-22-2009, 04:40 PM
megacabdad's Avatar
Oh yeah...
Those 12v's have that stealth bomber lookin' intake manifold!
That probably would cause some fitment issues.
My buddies is a 24v...perfect!
Old 08-23-2009, 02:21 PM
v10sport's Avatar
Anyone happen to have the Cummins part number for gaskets and the 2 longer bolts? I've got a 2G intake sitting on the shelf
Dodgezilla
51
05-04-2010 11:00 PM
BuckeyeRed
09-25-2007 12:04 PM
BuckeyeRed
0
09-24-2007 06:50 PM
goose2w1
05-16-2007 06:45 PM
Quick Reply: 2nd gen "INTAKE" manifold
