2500 vs. 3500 curb weight?
Old 11-07-2011, 05:26 PM
ScotS's Avatar
My truck is an '06 3500 Quad Cab 4x4 SRW short bed and our local DMV says it weighs over 7000 lbs. I saw a 2500 the other day with non-commercial plates. Over here, anything over 6500 lbs. has to have commercial plates and very high registration fees. The 2500 I saw was a diesel 4x4 Big Horn Edition. It was late and I was tired so I'm not sure if it was a Quad/Mega or short/long bed. I am fairly certain it was a 3rd generation truck. I got a partial VIN from the DMV guy and it's: 1D7KS28C26J. He couldn't give me the last 7 digits.
My questions are:
Does my truck really weigh 7000+ lbs.?
Is there any way that guy's truck could be under 6500 lbs.?
Anyone have actual curb weights from your truck that matches either of the versions mentioned above?
Thanks in advance! It really pisses me off that I have to pay more than $500 to drive less than 10k/year and this other guy is paying a lot less.
Old 11-07-2011, 05:35 PM
Fiftygrit's Avatar
First yes, its is over 7k in some state`s you can change the weight for registrations but then if you want to tow a heavier trailer or payload in the back you have to be careful, check your DMV
Old 11-07-2011, 05:55 PM
ho6speed's Avatar
I took a load of scrap steel to the local salvage yard and their scale said my truck weighed 7,600 empty with me in the drivers seat ( I weigh 175). I don't know how accurate that is but I guess its close.
I run regular car plates on my truck but the DMV clerk said I was subject to an overload ticket if I was caught hauling or pulling anything. It's a chance I take.
Old 11-07-2011, 06:38 PM
crackcorn's Avatar
I have several friends with simular trucks all 03' and above. We all work at a facility that has 4 state certified scales. I have not seen any of us less then 7000 lbs empty. My truck when it was new from the lot with out any of my personal items and a 1/2 tank of fuel weighed in at 7100 lbs. As of now with 35's and some personal effects it weighs 7600 lbs. I have gotten back down to 7100 lbs for running down the track, but I had to strip it including the spare tire...... Never seen a 3rd gen at less then 7k... But haven't weighed a standard cab 2x4, not even sure they made those with a diesel any how.
Old 11-07-2011, 07:02 PM
Lost Lake's Avatar
Mine is over 8,000 lbs. Stuff adds up! Air bags and brackets, fifth wheel brackets, tonneau cover, amps and subs, bigger tires and wheels, wheel liners, air tank, and train horn, before I had a lot of this stuff I remember weighing in at 7840 empty, half a tank of fuel.
Old 11-07-2011, 08:14 PM
annabelle's Avatar
Mine is over 8000lbs also. With full tank of fuel, me (180), full tool box, B&W turnover ball.
Old 11-08-2011, 07:35 AM
bettamsw's Avatar
my 05 reg cab long bed 2 wheel drive is 6250 empty.
Old 11-08-2011, 10:38 AM
Top's Younger Twin
Scotty's Avatar
I can push 9K with fuel in the slip tank...not even full. OINK!
Old 11-08-2011, 01:24 PM
dieselfreak21's Avatar
The only thing a 3500 has on to weight more than 2500 is is over load springs. Maybe 50lbs extra in comparible configurations (ie quad cab, long box 4x4) My truck as it sits in my sig with in it full of fuel is about 7300
Old 11-08-2011, 05:15 PM
AH64ID's Avatar
My truck is 8K flat without me (225) in it, thats with a few hundred in the tool box.
The 2500 vs 3500 SRW weights will be within 50lbs of each other.
Old 11-08-2011, 06:33 PM
Danavilla's Avatar
My '06 SWB, quad cab, 4x4 and near full fuel but without fifth wheel hitch went over the scales Thurs, at 7900, with me and grandson on board (325#total). That makes unladen close to 7580#
Old 11-09-2011, 12:44 PM
DBLR's Avatar
My registration lists my 2500 weight at 6300 Lbs even though I know its over 7K, I think the 6300 is the weight for a 2500 with a gas engine.
Old 11-09-2011, 01:26 PM
AH64ID's Avatar
Dodge lists your curb weight as 6862 lbs. The hemi is listed as 6105.
Old 11-10-2011, 06:34 PM
Rednax's Avatar
My bone stock 2WD SRW QC 5600 weighs -- with Leer topper, bedliner, full fuel & 195-lb driver -- right at 7,350-7,400-lbs from several CAT Scale tickets.
Without the topper, liner and the little bit of trunk junk carried, I might get near to 7k.
Old 11-16-2011, 02:03 PM
DBLR's Avatar
With 3/4 tank of fuel the last time it was on the county dump scale with me out of the truck it weight was 7278 and I don't have anything extra in the truck other then a spare fuel filter, a 11/8 wrench, a 12x16 tarp and about 20 feet of rope. Based on its weight I don't complain about it the reg listed weight of 6300 as I only have to pay license fees for 8K.
Quick Reply: 2500 vs. 3500 curb weight?
