24V manifold on 12V....pics
Just thought I would post some pics of my conversion to a 24 valve manifold in case anyone wanted to see. I could not find a 12V with the turbo location I needed for under $400(cummins direct), but I did find a 24V. I just squared the ports so there was no restriction at the port and it worked great. There is alot of meat in the manifold so sealing is still good.
I have over 300K on my 96 and over 500K on my 92 and no cracks on them. but may happen tomarow. had the one on the 96 off about a month ago and pulled the turbo off the 92 and was looking while I had it off and its fine. but I would like to have a 3 pice to cool things down.
1st Generation Admin
I like the lower location to keep heat and exhaust down low. It fits with my frame, so that is a plus. I had already built intake and exhaust plumbing for the low/rearward mount and I did not want to have to rebuild everything. It is a much bigger deal when you have to fabricate every piece.
Thanks, and 10/4 on that. This started as broken bolts in the head due to the PO making a mess. I used a liberal amount of antisieze lube and my calibrated right arm torque wrench to make sure they were not over tightened(lots of wrenching kindof teaches when the bolts stretch enough to maintain). I checked them after a couple days and a few lost a little torque so I finished the right arm torque sequence again. No leaks after two weeks and they are all staying tight.
