24V inline pump conversion lines
Old Oct 28, 2004 | 12:08 PM
Super4x4Duty's Avatar
I've called around several diesel shops looking for a set of conversion lines for my P7100 swap on my 24V and the best price I've found so far is $360. Anyone know anywhere to buy a set cheaper? Yes, I'm very cheap.
Old Oct 28, 2004 | 05:44 PM
Jetpilot's Avatar
Good luck doing a "cheap" conversion.
Doug
Old Oct 29, 2004 | 07:04 PM
Thanks for the encouragement, Doug. I'll break down how cheap I am for you. So far i'm ~$2,200 into my whole swap, including an '01 Cummins w/less than 10,000 miles (minus ECM and accessories), a '96 Cummins with a 215 pump for parts (complete from fan to NV 4500 bellhousing, turbo to oil pan *BUT* with a bad shortblock), an '01/02 six-speed flywheel & a Cummins to Ford conversion bellhousing. Didn't I say I was cheap? ? ? I know some guys swap the VP44 to an inline just to build more power or be more reliable, but I'm doing it because I'm swapping the engine into a Ford and it takes one more headache out of the equation. I'm aware of the popoff pressure differences and I don't think it will bother my combination enough to worry about it initially, but we'll see. Once the project is up and running I'll have a custom set of injectors setup for my specific combination since I'll probably throw some twins, lazer cut DV's and all the usual bolt-on stuff eventually. The only things left on the parts list are motor mounts, alt. mount, conversion injection lines and an exaust manifold that moves the turbo a little. Wish me luck!
bcool
21
Nov 25, 2008 06:26 PM
Teamropinram85
Oct 19, 2006 05:59 AM
Javahjoeo
Mar 28, 2006 07:57 PM
12valve
Feb 1, 2006 06:25 PM
windkid4
Oct 23, 2005 11:42 PM
