24 valve turbo on a 12 valve
my friend has a 2002 24 valve he switched the turbo on and said I could have his stock 1. is it the same as my 12 valve 1998 trucks turbo? and will there be any difference?
If it was a manual truck then the turbo would be the same, if it was an automatic it would be the smaller HY35, not a desirable turbo as a performance mod. Grab it if he's giving it away, keep it as a spare.
'89-'91.5 - Small H1C, 3" compressor inlet (non intercooled) 50mm compressor
'91.5-'93 - H1C, 4" compessor inlet (intercooled), 54mm compressor
'94-'95 - WH1C, wastegated 12cm exhaust housing, 56mm compressor
'96-'98 - HX35W, wastegated 12cm, 56mm compressor
'98-'02 (manuals) - HX35W, wastegated 12cm, some 8-blade 56mm compressors, some 7-blade 54mm
'01-'02 (automatics) - HY35W, restrictive 9cm wastegated housing (compressor, don't know)
'03-'04.5 (i think) - HE341W - 9cm wastegated housing, (compressor, don't know)
'04.5-'07 - HE351CW - 9cm wastegated housing, 62mm compressor
'89-'93 turbos have either 18.5cm or 21cm housings. All turbos after '94 will have MWE slots.
Feel free to correct me if I got some of it wrong.
RJ
05-17-2003 03:28 PM
phildog
04-02-2003 05:44 AM
