235hp or 245hp ?
235hp or 245hp ?
i have a 2000 dodge that i need a new injection pump i found a couple for sell used one is a 235hp, and the other is a 245hp witch one do i need or does it not matter?
My uncle works for a very reputable Bosch pump builder/supplier/dealer and recommended the 245 as that is the standard replacement....which I will be installing in the next week or two. If I were you, I'd buy new.
SO truck use the the 027 (235hp) pump and HO trucks use the 028 (245hp) pump.
The SO pump will put out more fuel if you're going for horsepower. The HO pump will probably give an SO truck better fuel mileage but lower overall horsepower.
Your HP is listed on the engine ID plate at the front, top, drivers side. It has your serial #, build code and other good info. Your hp rating is on it also.
Kurt
Kurt
I don't see why the HO Pump would be a standard replacement pump. His truck is an SO, so put an SO on it. Sure he might notice a little more oomph down low with a HO Pump. But once you start adding go fast goodies, the SO Pump out fuels the HO Pump.
Id stick with the SO (235)..
As I just learned the other day, The SO will cover down low AND up top while the HO will only take you so far power mod wise.
gitchyboy
11-22-2011 05:03 PM
Sinbadd
17
10-20-2007 10:56 PM
tyrod
01-28-2006 05:51 PM
LarryLuana
01-28-2006 05:10 AM
Mike67RS
07-24-2003 06:59 PM
