2007 4x4 Differential Servicing
Old 02-17-2010, 02:46 PM
RockinJohnny's Avatar
I am trying to change fluids on the differentials and I am having trouble locating replacement gaskets for the differential covers. The reason I am removing the covers is that I swamped the axels and the fluid is now tan in color.
My rear axel is a 11.5 inch and I don't know how to tell what the front axel is.
Old 02-17-2010, 02:49 PM
DBLR's Avatar
Factory gaskets are reusable if you don't tear or cut it when taking the cover off. IIRC the front is a 9.5 inch.
93-331-29psi's Avatar
permatex black. I don't think I've ever put a differential gasket in anything I've ever owned.
Old 02-17-2010, 04:24 PM
Dr.Dizzle's Avatar
Like DBLR mentioned,You can reuse the gaskets. Make sure to wipe off the gaskets and the mating surfaces prior to installation.
Old 02-17-2010, 04:52 PM
How much posi additive???
How many ounces of posi additive do you add to the 11.5 inch differential?
Old 02-17-2010, 04:55 PM
ripping r's Avatar
you dont need it.
Old 02-17-2010, 04:58 PM
May I ask why you wouldn't use posi additive in a limited slip rear end?
Old 02-17-2010, 05:01 PM
ripping r's Avatar
i have the limited slip rear. they use gears not clutches. so no additive is needed.
Old 02-17-2010, 05:13 PM
Dr.Dizzle's Avatar
Exactly. The service manual does not recommend the use of friction modifiers with the AAM units.
Old 02-17-2010, 10:36 PM
p035970's Avatar
Some axles chatter though. If your axle is one of these, the additive will stop the grinding sound.
Old 04-05-2010, 10:10 AM
Strea's Avatar
Okay, I bought Mobile 1 75w90 LS synthetic gear oil. Will this hurt my truck. Not sure I understood what the LS was for?
Thanks,
Strea
Old 04-05-2010, 10:32 AM
Oliverpuller's Avatar
Strea, that is exactly what I changed my axles out with just this past weekend. Mobil 1 75w-90 LS. 16,500 miles on truck factory fill in front and back looked the same, slightly dark gray in color.
Old 08-23-2010, 06:52 AM
singleturnout's Avatar
Bought some Mobil 1 75-90LS is it ok to run this in the diffs or should i go back and get the regular 75-90,wasnt paying attention when i bought the gear oil
Old 08-23-2010, 08:25 AM
TexasCTD's Avatar
Mobil 1 75w90 LS is fine. As long as it is GL-5 rated, any synthetic 75w90 brand gear oil is fine.
I have been running that fluid for 121,000 miles no problem since I first changed out my factory fill at 15K. 136K now on the truck. I change it every 20K miles or so now and it looks like new.
Old 08-23-2010, 12:35 PM
bradler's Avatar
re-use gaskets. make sure to clean around gasket/mating surface real good before pulling the cover unless you want to clean sand out of the gears. don't ask how i know this. and look for a fill line on the cover some people fill em to the bottom of fill hole but there is a fill line on some covers...
Quick Reply: 2007 4x4 Differential Servicing
