2004 sputtering engine performance issues
Old 11-13-2009, 12:49 PM
Red Feather's Avatar
I have a 2004 2500 6 speed with 127K and at the top end of each gear, say 2000RPMs - 2500RPMs the power seems to sputter and decrease but is ok when my foot is into it? Changed fuel filter and no change? Could it be injectors? They are stock and fuel tank and fuel seem to be clean. Air filter probably needs to be changed and will be doing that to see if that changes anything.
Any thoughts?
Old 11-13-2009, 01:33 PM
6 Shaker's Avatar
Sounds like it could be the lift pump if you still have the canister mounted pump. Have you checked your fuel pressure? I would think that you should be looking in this direction over injector changes.
Old 11-13-2009, 05:42 PM
You will have to forgive my lack of knowledge of full engine mechanics but I had the pump in the tank changed and assume your talking about the lift pump at the engine which I think is internal? I have not had the presure checked but will do that. Thanks!
bstiger
12-12-2009 05:42 PM
mooktank
12-19-2008 03:37 PM
JonnyThrottle
04-14-2008 04:37 AM
Joe V
12-13-2006 12:48 PM
JM_1
12-23-2003 09:23 AM
Quick Reply: 2004 sputtering engine performance issues
