2003 6 speed hard to get into gears.
Old 07-11-2007, 10:17 PM
2k1yzfr1's Avatar
I have a 03 2500 that I purchased new to pull my landscaping trailer and here lately it is extremely hard to get into 1-2 and reverse. I have almost 85,000 stop and go miles with 7500lbs behind it could the clutch be on it's last leg or is there something else that could be wrong with it? I changed over to amsoil fluids in the tranny and rear at 30k.
Old 07-12-2007, 05:06 PM
Bark's Avatar
I know this doesnt help since your problem is a recent development, but mine has always been a little difficult to get into 1st and reverse (but not second).
Old 07-12-2007, 05:34 PM
bulabula's Avatar
Your sig says that its sold. First thing I'd do is change the oil in the tranny and see if there's an improvement.
Old 07-12-2007, 09:50 PM
Jeff in TD's Avatar
Seems to be a common problem. Mine can be tough to get into gear after idling in neutral, and a buddy of mine has a truck that does the same thing.
Old 07-12-2007, 10:22 PM
2k1yzfr1's Avatar
Opps this is my brothers account......he sold his 03 6-8 months ago. I'll try to get some new oil and change it this weekend. What are some signs on the clutch going out???....just slipping?
Old 07-12-2007, 10:27 PM
gus's 03's Avatar
bad clutch = slips
bad slave = hard to get in gear
change fluid cheep insureance and probably needeed. use 6 qts, fill thru the tower. prob needs changed any ways..
Old 07-13-2007, 01:02 AM
2k1yzfr1's Avatar
How hard would the slave cylinder be to change out? Would this be covered on my bumper to bumper 100k warranty I purchased?
Old 07-13-2007, 04:47 AM
PourinDiesel's Avatar
You might be needing to change tranny fluid again.
Also the stock hydro's in the new trucks are pretty much junk.
Sometimes throwing the shifter into 3rd then going over to 1st might help you out a bit.
BigJohnston
20
07-14-2019 10:58 AM
93beater
02-28-2007 09:28 AM
Turbodude
01-04-2006 09:13 PM
walexa
30
04-08-2005 10:26 AM
Happy Traveler
13
12-08-2003 05:14 PM
Quick Reply: 2003 6 speed hard to get into gears.
