2002 t-case option
Old Aug 26, 2008 | 11:37 PM
quicksilvr's Avatar
2002 t-case option
What was the HD t-case and was it a separate option in '02 or did it come with a certain trans.
TIA,
Eric
Old Aug 27, 2008 | 03:12 PM
Stormin_Norman's Avatar
TIA,
Eric
The HD tansfer case option was just a PTO mounting plate as far as I know, the rest of the case was the same as the standard version.
Old Aug 29, 2008 | 02:04 AM
jefe4x4's Avatar
From Geno's:
"The NV241 is essentially a NV231HD with six gears in the planetary set.
The NV241D is a heavier duty Dodge version of the 241, with a larger input shaft and larger bearings to withstand the torque of the V10 and diesel engines.
The NV241HD, an option on Ram 2500's and standard on Ram 3500's built after 1998, has a stronger case and wider drive chain to better withstand the shock of snow plow service, a PTO cover and drive gear, and an extra bearing to support the thrust to the main shaft created by a PTO adapter."
231HD, 241D, & 241HD Transfer Cases
NV Gear Transfer Case Specifications
------NV231------NV231HD---NV241-------NV241D----NV241HD----NV271
Wt(lb)65----------72-----------80-----------100---------120----------NA
Input TQ730-------730---------1028---------1028------1400----------NA
Input TQ
(Max ft-lb)1,885---1,940------5,555---------5,555-----5,555--------7890
GVWR 5,920--------6,400------8,800--------10,500----11,000-------17,500
Fluid Cap(pt.2.5----2.5---------4.7-----------4.7--------6.5-----------4.0
It's interesting that even though the NV241HD has a wider chain and extra bearing and heavier case, the input Torque max rating is the same.
Note the NV271 in response to the 600 ft. lb. Cummins'
regards, as always, jefe
Old Aug 29, 2008 | 02:22 AM
quicksilvr's Avatar
Good info.
wyododge
Aug 18, 2011 07:48 AM
cnielsen4130
Jul 24, 2010 07:51 PM
torqueshop
Jun 11, 2010 11:00 AM
torqueshop
Jun 11, 2010 08:58 AM
