2002 rear disc brakes
Old 06-11-2008, 09:29 AM
mitchellalso's Avatar
Can anyone tell me how to adjust the rear disc brakes on a 2002 2500?
I have replaced the front pads a couple of times and the rear pads show very little wear. Is this typical? Is the brake portioning valve adjustable?
Old 06-11-2008, 11:27 AM
ewatters's Avatar
I don't think disc brakes can be adjusted in the way that drum brakes can.
Old 06-11-2008, 11:49 AM
SIXSLUG's Avatar
You can't adjust them. Very little wear is normal as they only provide 10-%15 of total braking unless you are loaded down.
The emergency brake pads are adjustable though, they are actually drum shoes in the inner side of the disc and are adjusted like drums thru the oval hole on the back of the flange by turning the starwheel. My notes say Drivers side down to tighten and passenger side up.
Mine were a real pain and I ended up pulling the discs and lubing the adjuster assembly as the pass side was bottomed out and stuck.
Kurt
Old 06-11-2008, 12:38 PM
infidel's Avatar
There is a load sensing valve on the rear differential with a rod that goes up to the bed.
Some people tie the rod down to mimic a full load, this provides more braking to the rears which results in a straighter, no nosediving stop and more even pad wear.
Old 06-11-2008, 03:04 PM
Thanks for the input. you have answered more questions than I posted.
Old 06-15-2008, 08:20 PM
phox_mulder's Avatar
2002 doesn't have the valve.
Valve went away when rear disc brakes came out.
phox
Old 06-16-2008, 12:17 AM
mudman78's Avatar
Rear discs are not adjustable and the rear pads will last twice as long, if not longer than the front pads.
Old 06-16-2008, 03:54 PM
Red3quarter's Avatar
They will last a long time. And if you live in an area where they salt the roads in the winter then the rear pads will rot apart like mine did a few winters ago.
1992 Renegade
10-11-2014 03:29 PM
Robert Rausch
11-17-2011 10:21 AM
2500CTD
10-19-2010 07:10 PM
wyododge
24
01-05-2009 12:19 AM
kwhite4
05-09-2005 03:22 PM
Quick Reply: 2002 rear disc brakes
