2002 ram trans line leaks
hello..
i have 2002 2500 ram,,the trans lines have actually got a leak/leaks ,,, due to the trans lines rubbing against each other.
question is will cutting out piece of alum trans line and replacing with 1/2 gas rubber hose , will this last???
i am not a fan of this method and looking for a better fix???/
any ideas?? i looked at local hardware stores for 1/2 alum tubing but cant be found . i guess i could buy 1/2 gas line kit for a race car set, use compression union but ,,,,not sure..
help.....
thanks
gordon
help.....
thanks
gordon
Replacement lines can be bought from Oreilly, Napa, Autozone at a fair price. In the past i have installed new lines and use some small radiator hose to wrap around the aluminum lines where points of "rubbing" may be an issue.
If I remember correctly the new cooler lines are around 30.00USD each.
trans line leaks
hello , and thanks....
i will check at either place...
was at an oreillys,,,and they didnt seem to be able to help...
but will check again or order online...
as i dont like rubber hose...
thanks..marty
thanks..marty
murfpcola
09-30-2013 12:20 AM
marksblaster
10-27-2012 11:26 AM
