2001 Overheating Problems
Old Sep 25, 2007 | 09:35 AM
Ryan Hyatt's Avatar
My buddy has an 01 thats all stock except for a straight pipe and hes having problems with it overheating. But its only when hes pulling a trailer and it goes all the way to the red, unloaded its fine. So does his truck have a thermostat that could be out or is it the waterpump.
Old Sep 25, 2007 | 10:00 AM
johnh's Avatar
check the radiator, it might be plugged externally,
if it still has the "puke bottle", oil vapors will attach to the radiator and stop the air flow
https://www.dieseltruckresource.com/...ht=puke+bottle
Old Sep 28, 2007 | 09:44 PM
DW Poyer's Avatar
2001 overheating problems
My 2000 3500 dually was doing the same. I was advised by a diesel resource thread and I pulled the radiator and found a lot of stuff plugging up the outside of the radiator. I actually took it to a radiator shop. They said the inside was fine. They did clean it and even rodded it out but they told me that the only thing they could see was the outside was oily and plugged up. I put in a new "Cummins" 180 degree thermostat and have pulled some pretty good hills with my 9000 pound fifth wheel with the heat guage going
up to about 200 degrees and no more.
Old Sep 29, 2007 | 01:48 PM
dj_souvlaki's Avatar
i gotta clean mine. i keep putting it off.
Old Sep 29, 2007 | 02:13 PM
Mikey G's Avatar
I had the same problem, radiator was plugged externally. I had to pull mine and get it cleaned at a shop, garden hose wouldn't do it.
Old Oct 3, 2007 | 11:47 PM
69plymouth's Avatar
I had the same problem. After a good degreasing and relocating the bottle, it doesn't even get to hot pulling my toy hauler (15000 lbs) in 110 deg weather.
mcfarmstrucking
Aug 10, 2007 12:24 PM
Rays01
31
Feb 12, 2007 11:36 PM
Mariner 250
Oct 10, 2006 03:31 PM
belfert
25
Sep 14, 2004 05:50 PM
Holycack
Jun 27, 2003 03:26 AM
