2000 ppm sulpher
Old 08-10-2011, 02:46 PM
Unless it's untaxed, then it's red.
#2isgreen's Avatar
2000 ppm sulpher
Any bad consequence to useing "diesel" with 2000 ppm sulphur in my truck? Cetane rating unknown.
Old 08-10-2011, 02:50 PM
maxwellp's Avatar
Talking
If it is this truck, No.
93 W250 4x4 CC LE
Denny T, Goerends converter, 2nd gen flex plate, pyro, boost & tach gauges, cooler tubz, 366, fuel cranked, piston lift pump,
4" straight pipe, M & H timing spacer, DNR POT kit, DNR intake, S&B filter, gloss black frame, deep/vented trans pan
Makes a lot more power and will get better MPG
Old 08-10-2011, 03:13 PM
deanhinsley1963's Avatar
Thats the good stuff if you can get it.
Old 08-10-2011, 03:19 PM
#2isgreen's Avatar
hmmm, its not highway rated...
but i've got a 275 gal tank connected to my furnace...
so as long as i trailer my truck to the race track, and do not drive on public roads, i should put a few gallons in the tank and run it hard!!
Old 08-10-2011, 06:30 PM
Yea offroad diesel has more Sulfur I think
A couple years ago before the big move to ULSD, there was a local station that had the older "Low sulfur"- not the ultra low
There was even a sticker on the pump that said "Not to be used with any Diesel Vehicle newer than 2007"
Old 08-10-2011, 06:41 PM
Tooth72's Avatar
im still looking for a place that sells on-road low sulfur diesel.. supposedly stations CAN still carry it but im finding that hard to believe... the only low sulfur diesel i can find is off road and im not going to risk the trouble it can get me into.. BUT if you keep it off the street and only on the track you can use off road diesel
Old 08-10-2011, 08:53 PM
MARF75's Avatar
I was told that off road and on road now have the same ultra low sulphur rating
Old 08-10-2011, 09:07 PM
Jklawinsky's Avatar
Originally Posted by marf75
i was told that off road and on road now have the same ultra low sulphur rating
x2..
Old 08-10-2011, 10:41 PM
pwrtripls1's Avatar
Correct. I had 20 offshore oil rigs under me and ALL diesel fuel is made with the same process. The Detroit or Cat gensets did ok with the change over, but the 2 stroke EMD's I knoticed a difference in KW output and barrels per day fuel consumption.
Contrary to urbin myth, on and off road diesel is the same. Closest to the old diesel is heavy fuel oil and ULSD mix. Too much trouble to go thru for that though. I've ran red diesel from the rigs for alot of miles and like it only because the price difference. Usualy it was free to fill mt 94 gallon dmax. Thats 2,000 miles of driving free.
Old 08-11-2011, 05:43 AM
#2isgreen's Avatar
What I'm talking about is home heating oil. I know its still diesel with no dye, but a friend tried to scare me off the idea saying it has lower cetane and will lower HP output.
Old 08-11-2011, 09:02 AM
carl48's Avatar
the opposite is true, it gives better mpg and higher hp
Old 08-11-2011, 09:49 AM
apwatson50's Avatar
off road diesel, home heating oil and pump diesel are all the same. The only difference is the red dye in the off road and the home heating oil.
Also the only reason why when you pull up to a off-road diesel pump they don't put the Ultra low sulfur diesel sticker on it is because they haven't cleaned the tanks and certified that all the old "high" sulfur diesel has been cleaned out.
Old 08-11-2011, 02:47 PM
pwrtripls1's Avatar
I agree with all but the heating oil. I thought home heating oil was more of a karosene mix. I could be wrong, but it takes alot of processing to get ULSD that clean for EPA reasons. Home heating oil is not under the same umbrella, so why would they super clean the heating oil to meet ULSD specs?
A few years ago when I lived in maine some stations had pumps for road diesel, offroad diesel, and off to the side they had heating oil that was marked as karosene.
DODGE4X4
30
11-08-2007 02:24 PM
95ram
04-10-2007 05:32 PM
Chip
16
06-02-2006 09:52 PM
CACalomino
05-30-2006 12:59 PM
highoutput75
27
05-06-2006 08:03 PM
Quick Reply: 2000 ppm sulpher
