20 mpg ?
Old 02-27-2008, 07:06 PM
06er's Avatar
20 mpg ?
just bought my 01 and it has a 5inch lift with 35s is it possible to get 20mpg with that set up. My first tank it figured out to 15mpg but i dont belive that the speedo is recalibrated. Would it be easier to get 20mpg if i would just level it and put 33s on it?
Old 02-27-2008, 07:53 PM
HOHN's Avatar
The lift is killing mpg. The tires aren't helping that much, either.
Dropping it to a basically levelling kit and 33s should help you pick up 2-3mpg.
jmo
Old 02-27-2008, 07:56 PM
babyjoe's Avatar
Do you have pics of you 01, I'd like to see it with the lift.
Old 02-27-2008, 08:01 PM
sewman's Avatar
I don't know if 33's will help much it's the width of the tire that cuts into the rolling resistance,a narrow like a 255 85 16 might help more.
Hohn is correct about the lift.
Old 02-27-2008, 08:40 PM
TNutcher's Avatar
not sure how much it compares to the added weight and rolling resistance but wouldn't the benefit outweigh the cost on taller tires like 35's in that they add better freeway cruising gearing, ie lower RPM at same speed as 33's or even the 265's??
TNutcher
Old 02-28-2008, 12:29 AM
bullboy85's Avatar
my setup gets 23mpg freeway, hand calced. im running 265s but got a flatbed and really heavy bumper i think id be doing better without them
Old 02-28-2008, 02:42 AM
JoeLee's Avatar
Here is a 2 1/2inch Lift
Old 02-28-2008, 07:43 AM
Dartmouth 12V's Avatar
Both the lift and the tires are really hurting you. The most important factor in fuel mileage at highway speeds is wind resistance because it is proportional to the square of the velocity. Both of them are raising the truck so you have more air going underneath it which is a bad thing. The tires also probably have a wide contact patch which increases rolling resistance some. The benefit in gearing does not make up for the windage and rotational inertia of the taller tires. If you are looking for mileage and run mostly highway, try a 235/85/16.
In town it is slightly different. The real problem with tall tires there is the increased rotational inertia. It takes a lot of energy to accelerate those tires up to speed all the time.
Old 02-28-2008, 05:20 PM
babyjoe's Avatar
(JoeLee) thanks man looks good, thats just about what I want on mine....what did it cost/brand?
Old 06-17-2008, 02:42 AM
JoeLee's Avatar
babyjoe, skyjacker 2 1/2 inch leveling kit if I am not mistaken it is the sj d25
here is a link below, sorry it took very long to reply...
http://store.summitracing.com/partde...5&autoview=sku
Old 06-17-2008, 07:45 AM
high bid's Avatar
In town easy driving 18.5 mpg
on the hwy cruise set @ 65mph 21mpg w/the current mods listed. Even w/diesel at $4.69 I still can't see the cost benefit of buying a ricer. My break even point for buying a ricer I think about 4 years to payback, not worth it IMO.
Old 06-17-2008, 01:15 PM
govspringbounce's Avatar
Ditto ... aero + rolling resistance. I'm also using the 235/85/16's. I'm using the BFG Commercial TA's, M&S rated. Great off road & on ice & snow.
bngcustoms
45
06-20-2009 06:55 PM
richard
26
09-06-2007 01:35 PM
bigfish5
09-19-2006 12:56 AM
Maddog
01-03-2003 10:01 AM
rshelton88
15
12-22-2002 09:40 PM
Quick Reply: 20 mpg ?
