2 Ton Truck vs. Dodge Cummins
Old 12-02-2005, 08:19 AM
ISB
ISB's Avatar
What, if any, differences are there be between the 5.9 195Hp Cummins in my '97 F800 two ton truck and the Dodge Cummins of the same vintage? I found out that the oil filters are the same. There is probably a different fly wheel set up. This is my first 12V and Its great sounding with that big exaust In fact, the exaust may be a Catylitic type because it says not to burn waste oil or it will damage it? Just curious about crossing performance parts between the two or is one stronger than the other?
Old 12-02-2005, 08:37 AM
durasmack's Avatar
As far as I know, they should be the same. Your F800 likely has different gearing on the tranny, maybe different fuel plate, but thats all i can think would be that much different..... Bill will know if he makes it over here....
-Trey
Old 12-02-2005, 08:41 AM
Rhino's Avatar
Often times the fuel pumps are different between the applicaitons.
Old 12-02-2005, 04:40 PM
mr T's Avatar
same engine same pump just they call it a 190 pump..they may have a slightly different fuel plate..different air filter....come with allisons often times and 6 speeds
Old 12-02-2005, 06:04 PM
Rhino's Avatar
I'm sorry I did not mean a different fuel pump all together. Of course it is still a P7100. I meant different in the same way a marine P pump is different than a on-road P pump or how a 160 P pump is different than a 215 P pump. There are more differences between those than just a fuel plate. I'm guessing the 195 pump being asked about has some of the same differences.
John H
10-14-2004 06:46 PM
dieselnewbie
03-16-2004 07:15 PM
The Roamer
12-15-2003 07:40 PM
dealseeker
24
12-18-2002 10:39 AM
dhe9
10-28-2002 04:57 PM
Quick Reply: 2 Ton Truck vs. Dodge Cummins
