2 part question
Old 12-06-2004, 08:05 PM
Jmac's Avatar
2 part question
1. Should there be any leakage around the Transmission Pan. B/C I do.
2. I just noticed what looks to be a breather tube (black) that looks as though it comes all the way from the top/back of the motor to the bottom just above the front differential. and it's leaking what I think is dirty oil? leaked enough to get the back side of the diff oily.
are these leaks normal
Jamie
Old 12-06-2004, 09:40 PM
cquestad's Avatar
That is the blow by vent from the crank...
It is normal for it to drip/splash back some.
Old 12-06-2004, 09:45 PM
cquestad's Avatar
I mean valve cover...duh...it is late...need to leave office.
Old 12-06-2004, 09:48 PM
handymantim's Avatar
Just my opinion but a truck that new shouldn't be leaking anything. Make 'em fix it......if you can trust them to actually fix it.
Old 12-06-2004, 10:07 PM
Jmac's Avatar
Well I just went ahead and changed my tranny fluid do you guys know how much it is to refill? approx 6 quarts came out. I measured the used fluid. just don't want to overfill.
Admin Team Leader
Lary Ellis (Top)'s Avatar
The blow by tube is a normal occurrence, it may spit out a little oil from time to time. You can fasten a plastic bottle to the hose to catch it if you wish, just remember to empty it once in a while.
Sounds like the pan gasket is leaking a little on the tranny, it may just need to be tightened up a little bit. If you do it yourself, be sure to follow the torque specs as the bolts are threaded into aluminum and can strip easily if you gorilla wrench it
Old 12-06-2004, 10:14 PM
Jmac's Avatar
what's the refill Amount anybody.
Old 12-06-2004, 10:29 PM
torquefan's Avatar
Refill amount- you kinda gotta play it by ear. The trans will hold over 12 quarts, but on a service, you get less than half out. Put in 5 quarts, then run the truck and check the level. Repeat as necessary.
Old 12-06-2004, 11:51 PM
Jmac's Avatar
thanks torquefan, I wound up going about 2mm over the fill mark.. I think thats ok because It came much more full from the factory... more like an inch over to where the dipstick is S shaped bent.
Jamie
NoSparkplugs
06-24-2009 07:08 PM
77machomopar
01-24-2008 05:30 AM
swimmy
04-29-2005 04:56 PM
SmokinFive9 4x4
03-07-2005 06:55 PM
12PACK
01-02-2005 06:48 PM
Quick Reply: 2 part question
