2 Micron Fuel System
Old 09-06-2009, 09:43 PM
Franklin's Avatar
Hey guys Im getting ready to install this system from GDP....
http://www.glacierdieselpower.com/pr..._id=FW1220-TFK
So do you guys run this system and keep the stock canister? Will it work out ok? Should I switch the filters for CAT's?
Old 09-07-2009, 07:34 PM
8mpg's Avatar
If you have already purchased it, Id just run the filters that come with it and change over to CAT 2 mic when its time to change the filter. I wouldnt bother change the water sep, the Fleetguard is fine.
I would keep the stock fuel filter housing for heating purposes...wouldnt bother run a filter in it.
Old 09-07-2009, 10:47 PM
Snoxracer's Avatar
I kept the stock canister filter then run the GDP 2 micron set up. System works great, but I probably will be moving the mounting under the truck because I am really wanting to get twin pumps on this thing!
Old 09-07-2009, 10:48 PM
Snoxracer's Avatar
Also you can see that I tapped the filter housing to install my fuel pressure sensor, then I know exactly what is going to the pump.
Old 09-08-2009, 01:29 AM
rufushusky's Avatar
This is your most cost effective option. I say run the FG for now and then maybe switch to a 1R0750 filter. If you do go with your original idea then I would keep the FG W/S since they are a bit better than the Cats. I am running a homemade setup which is pretty much the same as the GDP set up you posted.
Sorry my camera skills are not the best.
Parts List:
2 x Baldwin BF1311 filter heads
2 x -10 O-ring ti -6 JIC
2 x JIC to barbed fittings -6
1 x -10 O-Ring union
1R750 2 micron filter
175-2949 Cat W/S, not the best W/S but I have a baldwin PF7977 in the canister to help with that.
Last edited by rufushusky; 09-09-2009 at 02:26 PM. Reason: I speak english I swear!
Old 09-08-2009, 02:39 PM
ScienceOfSpeed's Avatar
i have the FASS 150 on my truck, can i use the Fleetguard 2 micron filter on my FASS?
Old 09-08-2009, 03:23 PM
rufushusky's Avatar
Sure it is not a true two micron, it is really a 5 micron filter absolute but still pretty good.
Old 09-08-2009, 03:32 PM
well is there a true 2 mic filter that can fit on the FASS pumps?
Old 09-08-2009, 03:42 PM
rufushusky's Avatar
To the best of knowledge no...
http://www.fassride.com/filter-cross-references.html
The real thing I would be concerned with on the Fass is not the Fuel filter but the water seperator...its numbers are less than stellar.
Old 09-08-2009, 05:02 PM
i found a 20 micron Fleetguard water separator pn#FS1212 , from what i was told it will work on the FASS
Old 09-08-2009, 05:07 PM
rufushusky's Avatar
It is a 1-14 filter so it will fit but I was told fass does not what anything tighter than a 100 micron filter on the suction side of the pump.
sallyman1
04-19-2011 06:31 PM
Jason_K
37
01-12-2009 05:07 PM
03RAM2500
01-11-2009 05:21 PM
vj_M
04-25-2008 10:01 PM
Franklin
04-12-2008 02:09 PM
Quick Reply: 2 Micron Fuel System
