2 Mic Filter Question
Old 01-03-2008, 12:19 AM
Pinksa's Avatar
Im going to install my Fass pump soon and had a filter question..Can i run a 2mic between the Fass pump and the factory filter housing, then to the Cp3?? What are the Pros and Cons? Thanks in advance
Old 01-03-2008, 12:22 AM
trik396's Avatar
That's the way I do it... minus the Fass.
Old 01-03-2008, 12:26 AM
Pinksa's Avatar
Awesome. I appreciate the reply
Old 01-03-2008, 12:38 AM
BlueDually's Avatar
you want the 2 micron right before the cp3, after the stock filter.
Or just put a 3 micron filter on the fass, (if you have the fass with filters)
Old 01-03-2008, 12:41 AM
Pinksa's Avatar
No i dont have the Fass with Filters.. I was going to cut the line on the frame rail to mount the filters. Why does it have to be right before the CP3??
Old 01-03-2008, 01:04 AM
trik396's Avatar
You don't have to have it after the stock filter. I have 2 two micron filters in my toolbox that are fed from my pump, then go to the stock filter canister which I kept only because of the fuel heater. Probably don't even need the filter in there but I run one anyway. Some guys say it's backwards to run the 2mic filter before the 10 or 7 stock filter but it was easier for me because I run two huge CAT filters. They're about a foot long each... no way they'd fit in the engine compartment.
Old 01-03-2008, 01:25 AM
DaveB.inVa's Avatar
They're saying to stage the filters so you filter progressively better before the fuel makes it to the CP3.
Like on my setup the fuel first goes through a 24 micron strainer at the Glacier pump. Then it is filtered at 7 microns at stock canister. Then it is filtered down to 2 microns using the Glacier kit.
Hopefully the 24 micron unit will catch everything 24 micron and larger. This will allow the 7 micron filter to only have to filter particles in the range of 7 microns to 23 microns. Then the 2 micron filter will hopefully catch everything 2 micron to 6 micron.
This is a way to make sure the filters will last the longest. If I had my 2 micron filter first in line it would have to catch everything 2 microns and larger. If that was the case and the 2 micron filter did filter out everything 2 microns and larger, the 7 micron filter wouldn't catch anything because they're wouldn't be anything in there to catch so what would be the point in having it in the system.
Some folks running a remote mount 2 micron filter will run a line from the stock canister down to a point on the frame to the 2u filter then back up to the CP3.
Old 01-03-2008, 02:10 AM
trik396's Avatar
Still its not necessary. The aftermarket 2mic filters are generally MUCH larger than the wimpy stock one. They can hold alot more junk and filter much better. I have a pre-pump 75micron, then the two CAT's then the stocker. Overkill is just about right for me.
Old 01-03-2008, 10:39 AM
omaharam's Avatar
That's what I did.
Old 01-03-2008, 11:31 AM
6-Pack's Avatar
Any of you guys in colder climates (down to -20 or so in the winter) having any gelling problems with your remote mounted filters? Especially when mounting on the framerail, far from the engines heat.
Old 01-03-2008, 11:56 AM
DTR's 'Go to Guy'
vzdude's Avatar
Mine is located under the hood. I drilled and tapped the intake horn for a mount. It is also inbetween the factory filter/heater unit and the cp3. I was concerned about waxing the filter or gelling with it anywhere else. I know I'm only about 90 miles away from trik396, but I'm out where the wind blows with nothing to stop it and no garage. Just wanted all the heat I could get near it!
Old 01-03-2008, 12:44 PM
Pinksa's Avatar
hmmm. Seems to be some good points
Old 01-03-2008, 02:12 PM
trik396's Avatar
I used to have it underhood. Now they are mounted in my toolbox. They are out of the elements but it's still brutally cold in there.
-4 this morning when I got off of work. No problems.
Old 01-03-2008, 02:37 PM
Pinksa's Avatar
HAHA. its never that cold in Texas
Old 01-03-2008, 05:06 PM
6-Pack's Avatar
Good to know! Just a little too crowded under the hood for me. It's hard enough to get at things in there the way it is now.
Quick Reply: 2 Mic Filter Question
