2 gear grind
Old 11-30-2005, 11:55 PM
West Coast's Avatar
2 gear grind
Once in a while I get a little grinding when put it into 2 gear on my 94 CTD 5 speed. I am putting in a new clutch next week so I figure I will have my tranny guy give my tranny a once over. What are some of the common issues on a 94 5 speed tranny that I should have checked?? Thanks....
Dave
Old 12-01-2005, 08:49 AM
newriverSpecon's Avatar
If it doesn't already have one use an aftermarket pilot bearing. SB makes a kevlar one. Quad 4x4 sell a couple of different ball bearing one. Any option will require machining the flywheel. Should be less then $100 for the work.
I made the mistake of not going that route the first three time I had my trans out for clutch issues. I also was concerned about my syncro's bitting the dust but wow what a difference when the trans completly disconnects. The bearing that came with my new clutch was such a pile that the cage that holds the neddles in ground on the shaft (which was already marred from the first one). All is well now and same input shaft.
Randy
Diesel Dave2
15
06-03-2013 10:02 PM
Bogurt
05-30-2012 11:12 PM
stroker4501
10-01-2007 10:35 AM
Wilson
12-18-2006 12:47 AM
s cesnick
13
07-19-2004 02:15 PM
Quick Reply: 2 gear grind
