1999 quad cab?
1999 quad cab?
I have a 1999 dodge diesel 2500. It has the two rear doors that swing open torward the front like suicide doors. Is my truck a quad cab, extended cab or what?
The Club cab option wasn't actually deleted from the option list until halfway through the 2000 model year but as you can imagine, during the 2.5 model years that it was offered with the Quad cab, it wasn't very popular so it will be somewhat rare to find one after the 97 model year.
Just a plain ole guy
Here's a tip for a 99 owner. Get a 1/2 id rubber hose and push it onto the ac drain tube. You'll see a stub about 2" long sticking out on the firewall. Get a hose long enough to extend down a bit. Mine goes just below the frame rail. The drain tube has a flared type end on it so no clamp is needed.
I'm sayin this because if your ac isn't leaking under the carpet yet, it should soon. The seal around the penetration shrinks, the water follows the tube back to the firewall, and in time, your truck stinks inside and you need new carpet.
89dieselkong
07-27-2010 10:55 AM
