1998 dodge ram catalytic converter removal ?
anybody remove the catalytic converter and does it make them run better ?
better mileage ? im usually getting around 28 if drive around speed limit and good run on highway . thinking of number 10 torque plate ? what advantages and disadvantages ? are they safe ?
You know it is illegal to remove the converter. If someone were to crawl under there and find out you sawed it off with a sawzall and then replaced it with a piece of straight pipe and a couple of clamps, you could get in big trouble. And if you did violate this federal law, you would be eliminating an emmision control device that doesnt do anything whatsoever except increase back pressure which makes your engine work harder to produce the same amount of power therfore burning more fuel which increases exhaust produced therefor lowering your MPG and increasing EGT's which shortens engine life.
Undertaker
29
11-18-2010 07:40 AM
GaCamper
10-25-2008 10:33 PM
Hummin Cummins
04-10-2003 10:29 PM
