1995 -lights blinking ???
1995 2500, Headlights irradically blink off momentarily. sometimes JUST the radio time display will come on real bright . like 'Christine' in the Fury ,
all gauges still work fine,normal gauge lighting unaffected.any help appreciated. DAVE
Hello, sounds like your headlight switch is going bad to me. I had the same problem with my headlights but the radio lights were unaffected. My problem was the multifunction switch on the steering column though . So thats why i say it's the headlight switch on the dash. From what i hear it's a pretty common problem.
-Kyle
-Kyle
Does it happen when you 1st start the truck, when its cold out. Cuz if it happens then, then its your grid heaters warming up. I asked about it too.
https://www.dieseltruckresource.com/...dlight+flicker
If not, then I'm not sure, unless you are drawing power from your batteries (stereo system, ect..)
Good luck,
Hunter
Good luck,
Hunter
Thanx guys , It's not the grid heaters I'm used to that . i believe it is the headlight switch once i got a chance to wiggle everything I can make it do it at will. I actually had a guy pull over in front of me tonight on the way home. maybe I'll leave it alone:-), DAVE
I Stand Alone
01-26-2011 04:33 PM
frank compagnon
06-27-2010 03:14 AM
WS6HUMMER
03-10-2006 02:11 PM
