PDA
View Full Version : 1978 dodge diesel???
redhornet
12-08-2005, 11:02 AM
A friend told me his naghbour has a 1978 1/2 ton parked out back and it has a factory diesel,what kind of engine would that be?thanx
bgilbert
12-08-2005, 11:06 AM
6 cylinder non-turbocharged Mitsubishi turd offered for two or three years 78-79 or so.
derek840378
12-08-2005, 11:48 AM
a little 3.9L piece...
tboling
12-08-2005, 11:53 AM
Hey is he pulling your leg? I know for a fact that dodge put 354 perkins engines in there 2ton trucks in the late 60's early 70's. And the firt cummins engine in a Dodge truck was a 290 it stands for 290 hp their in the D700 and D800 trucks yes there inline 6's.
Underpsi
12-08-2005, 12:03 PM
no im with bgilbert on this one, 6 cylinder non-turbocharged Mitsubishi turd offered for two or three years 78-79 or so. I saw a post on rcc about this its definitely the mitsu motor, i heard there good for nothing. If i recall properly they don't even get very good mileage either
BearKiller
12-08-2005, 03:28 PM
I looked at one on a local lot a couple years ago; I think it was a 76 model and it was Mitsibishi inline six.
stillsmokin
12-08-2005, 07:06 PM
I am with bill on this one too. They made a full size N/A diesel back then. There is a near perfect one 30 miles from me. Are you sure it is mitsubishi though? The guy who owned it told me it was a small N/A perkins. I was thinking the mitsubishi motor was in the ram 50 diesel.
sgibson
12-08-2005, 08:28 PM
I'm with Bill, the big trucks were history(US) in78 I don't even think there was a lifestyle cab that ever had the perkins in it, c-cabs had them in the class 5&6, I'd bet its a mitsu 243.
greatwhite
12-08-2005, 08:45 PM
Something is jogging my remembery that it was an Isuzu diesel in the D150 models in the late 70's.
Underpsi
12-08-2005, 09:33 PM
the Ram 50 would be a 4 cyl diesel not 6 and im not even sure if they had diesels or not [duhhh]
spunbearing
12-08-2005, 10:48 PM
The ram 50 did come with an optional mitsu diesel and they are supposed to get 35+ mpg. The ram 50 to my knowledge wasn't available until 82 or 84 I think. The one he is talking about is a full size half ton.
txs
12-09-2005, 09:58 AM
http://www.pbase.com/txs/image/45203467 This is a pic of the mitsu NA 6 out of a 1/2 ton dodge, I believe it was a 78 or 79, they were indeed such a slug that nobody wanted one and were only offered 2 or 3 years and that was probably the unsold production left over from the first year. The motor is laid out similar to a cummins in that the block has no cast in bell like gas motors, there is a flywheel housing (adapter), in the mitsu dodges it bolts to an LA case. You can tell it's out of a dodge if you look close at the converter. Dodge made several 727s for diesel apps in the eighties, the mitsu was the only one that used the a case, most used the b motor case.
tboling
12-09-2005, 10:39 AM
Hey guys I want a ram 50 diesel bad any one know of any around it the U.S? I've been looking for one for a long time but have never seen one and now I want a 78 diesel to . :D
russ300h
12-09-2005, 11:17 AM
I owned one years ago. It was definately a Mitsubishi inline six 100 hp. Sweet running engine, but a real slug. especially with the automatic that mine had. A few Ram 50's came through with a 4-cyl diesel in the early 80's. Made by Mitsubishi as they made the truck!
ChrisLib
12-09-2005, 05:02 PM
here ya go...and the auction has`nt even ended yet! hurry hurry hurry :D :D :D
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4595388417&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
FWIW those little Mitsu diesels are really neat, I worked for Mitsu since 1985 and we saw a couple of them here and there, biggest thing is to make sure you keep the Timing belt serviced on schedule, and there used to be a TSB regarding the t-belt and inj pump timing, IIRC the srevice manual specs were wrong...it was a looong time ago.
spunbearing
12-09-2005, 07:23 PM
http://i22.ebayimg.com/04/i/05/a5/ac/6f_1.JPG
awwwwwwwwww how cute :D
FNJ
12-10-2005, 02:05 PM
A buddy of mine has 87 Jeep Comanchee with a Peugeot turbo diesel in it the turbo is about the size of a fist and the intercooler is about as big as a small trans cooler. And the the truck is very very quick!!
