170 to 215 pump swap
Old 05-14-2007, 04:23 PM
Pickin on the wrong admin...
Diesel Dave2's Avatar
Just wanted to know who has done a 170 to 215 IP swap?Want to know the perforamce gains by doing this swap.The 215 pump will get the 3K springs and the #10 plate.I will also be keeping the stock HX35 turbo.
Old 05-14-2007, 05:13 PM
Box5's Avatar
I think it would be a nice upgrade because the 215 pump seems to get alot more aggresive with just a plate compared to the smaller pumps. I guess u'd just have to wiegh to price and gains. If u get a great deal on a 215 pump i'd do it, then u can sell the 170 to re-coupe quite a bit.
Old 05-14-2007, 07:28 PM
Muddin_dude06's Avatar
I would take the 170 to a pump shop and see how tricked out they can make it IMO. If you are going to get crazy with power than you *could* have the advantage of extra EXTRA rack travel that the 215 can not do.
Old 05-14-2007, 07:36 PM
TheBigNasty's Avatar
Well you know, If you want I'll trade you my 170 for your 215.
Old 05-14-2007, 11:04 PM
ratsun's Avatar
I went from a 180 pump to a 215 pump and the 215 injectors. I installed the #10 and GSK kit at the same time and its a real kick in the pants. I would guess it was somewhere around 100hp. You will out of air with the stock turbo
Old 05-15-2007, 05:21 AM
schoust's Avatar
Not to steal your thread but I was wondering what kind of flow can be had with a 160 pump? Can this be turned up accordingly by the right pump shop or would I be better off just getting a 215 pump and going that way??
Old 05-15-2007, 12:15 PM
Good question...I know guys installing the aftermarket DV on the smaller pumps.As for anything else,I'm not sure,unless you start ripping the pump apart and start installed a beefer cam profile...
Old 05-15-2007, 02:00 PM
Ram of Steel's Avatar
I'm running 215 injectors with a 180 pump 10 plate and 3K gov.
3500 RPM, 38 PSI boost and runs like a striped *** ape. I pull a 40 foot 5'er and have power to spare. Even in the hills.
Old 05-15-2007, 06:19 PM
mr T's Avatar
if you're gonna swap just get ur current core built to whatever u need by any of the reputable performance guys. May cost u a few bucks more but u will have new internals and a serious pump for whatever u need
Old 05-16-2007, 08:13 AM
gunracer1's Avatar
they don't put new internals in most pumps. the rebuild most of the time is just a good bench tune with a over priced tag.
12valve
06-20-2006 08:04 PM
BrewPub
06-04-2006 09:11 PM
signature600
02-04-2005 09:25 PM
Trickytrae
04-20-2003 04:00 PM
gunracer1
12-27-2002 11:34 PM
Quick Reply: 170 to 215 pump swap
