1687 code
Old Aug 3, 2005 | 11:03 PM
Ian's Avatar
Ian
1687 code
that one just means that no message is getting from the guage cluster...due to possibly a short of some sort, correct?
Ian
Old Aug 4, 2005 | 01:04 PM
phox_mulder's Avatar
Correct.
Short or loose connector could throw the code.
phox
Old Aug 4, 2005 | 07:27 PM
Ian's Avatar
Ian
perfect. thats a relief. I think this code (or short) also triggered my abs and brake lights to go on. Any ideas on how to remove them?
Thanks again,
Ian
Old Aug 4, 2005 | 07:32 PM
crobtex's Avatar
The ABS and brake lights could be caused by the speed sensor in the rear axle.
Pull the ABS fuse and see if they go off. You could do a complete system reset by disconnecting the batteries and leaving the ignition key in the "on" position for about half an hour.
Old Aug 4, 2005 | 07:39 PM
Ian's Avatar
Ian
crobtex: thanks, I'll give those a try. The abs and brake light came on after I shorted out the guage cluster. shouldn't have been the speed sensor. kinda odd IMO
O.T
Sep 6, 2007 06:10 PM
Hammered Scout
Aug 10, 2006 10:12 PM
duner
Feb 19, 2006 05:42 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
