160HP P-Pump limitations?
Old 02-25-2008, 06:40 AM
Troutstrannysvc's Avatar
I'm wondering how much fuel have people pushed out of their 160HP pumps reliably?
What amount of fuel is needed to reach #600-675HP/1000+ TQ?
And can the #160 pump be sufficient up to those numbers?
What am I looking at price wise to get this pump push 300-400CCs of fuel, what needs to be replaced? Plungers, barrels?
Note; I am not looking to "buy" a performance p7100, I am looking to get mine on the bench behind the propper mechanic and letting them work it.
So if you wanna point me in a different direction IE - 180,215 pumps, then please offer information as how they compare to the 160.
Thanks in advance
Old 02-25-2008, 07:31 AM
John Faughn's Avatar
Want to see answers .
Old 02-25-2008, 08:00 AM
logskidder's Avatar
600'ish on a 160 that has never been off the truck........Jeff Garmon
Old 02-25-2008, 08:10 AM
logskidder's Avatar
Watts Fuel Injection Service in Derry Pa, He is close to you and he can bench your pump.
Old 02-25-2008, 02:42 PM
schoust's Avatar
I would like to know the same I have done everything I can do except the rack plug but as soon as I get a decent day thats a done deal. I have heard that that over 600 is possible but with a good set of twins and a push pump like a Holley Black behinde it...
Old 02-25-2008, 09:52 PM
ratsun's Avatar
Thanks in advance
Send it off to Piers at
http://www.peakdieselperformance.com...ge/4863102.htm
He starts with those pumps to make his ~ Stupid Pumps ~
It will flow as much as you want
Old 02-26-2008, 03:00 AM
cumminsdriver635's Avatar
The 160 should flow plenty for 600hp without ever coming off the truck with the right injectors, pusher pump, DV's, turbo, etc.
Old 02-26-2008, 10:38 AM
kawi600's Avatar
You can get a reman 215 for under 1000$ if you look around. I think the pressures are a little higher than the 160. Might change the fueling a little versus a 160 with good injectors. Could always just try injectors alone and see what you think. Youll need more air soon and probably want to o-ring/stud and get 60lb springs then.
Im going for a small increase with a set of DDP2 or 3's and match them with a phat shaft 62 later on. Trying to stick with a smaller single for the spooling.
My pump might be a little tired, no cheap way to find that out unfortunately.
Or maybe there is? worth a post..
Old 02-26-2008, 01:20 PM
Thanks for the information regarding the reman 215.
Head is O-ringed, 12MM Studs, #60 lb valve springs.
Plan on putting a SPS62 here in the very near future a long with a set of 435's, or Hot Rod 370s. Will also be running a Helix II Cam.
Does anyone know the flow differences on a 160 VS 215?
-Jared
Old 02-26-2008, 02:40 PM
The pumps have different cams in them, which is the main difference from everything I have heard. You can have your pump calibrated for about $500 or less, and supposedly a tweaked 160 is better than a tweaked 215.
Eric
Old 02-26-2008, 02:48 PM
Mcmopar's Avatar
Two words
Scheid Deisel!!!!
Old 02-26-2008, 08:54 PM
tom25's Avatar
Seen a guy run an 11sec 1/4mile on a hopped up 160 p-pump
Old 02-27-2008, 12:26 PM
bluthndr's Avatar
Thumbs up
Originally Posted by Mcmopar
Scheid Deisel!!!!
I looked at doing what you are talking about: 913 pump (215hp) vs send out my 160 to have it "tuned". I sent mine to Scheid, and I don't think they replaced internal parts (like cam, plungers, barrels, etc), but they did enhance it somehow (trade secret stuff I'm sure), and reset the timing.
Before I sent it out I dyno'd 325 hp at the wheels (David Dunbar's DynoJet)with 370s and off the shelf parts in the pump and a WH1C (older HX35). This was on 40" tall 18" wide Boggers (TONS of rolling resistance & weight), so "real" numbers were probably a little higher.
After I got it back, it will put out 385 to around 500 to 550ccs (don't remember exactly). With a S300 62/14, and bigger injectors (5@.016 I think), and a fire ringed head and thicker gasket, I dyno'ed 425hp - on the same tires & dyno - with the pump set at 400ccs and the turbo wastegated at 40 psi. There's plenty left in it I'm sure - I will try it on "little" radials later this year and then turn up the fuel. Oh - no pusher pump either for what it's worth.
Long story short, yes, I think a 160 pump will put down a good 600+ hp with the right combo. I have no doubt Garmon did what he claims - he is good - but for the rest of us, he should have a "results may not be typical" disclaimer in his sig.
For what it's worth I would seriously consider 14mm studs while you are at it. I blew my fire-ringed head gasket 4 TIMES with the 12mm studs when I first got it all back together. 14mm solved it permanently.
Anyway - the cost of buying a recon 913 pump vs sending mine (160hp)to Scheid was almost the same (Scheid I think waas actually a little less), and I'm happy with the results - good people there that can answer questions - not just a reseller/rebuilder that sells recon pumps. Hope this helped.
deerslayer1979
06-08-2010 10:28 AM
winkdemon
ABDTR #5
25
02-13-2009 09:39 AM
cumminsdriver635
08-12-2005 12:45 AM
AWray
45
08-25-2004 12:28 AM
PSYCHORAM
16
04-15-2003 02:27 AM
Quick Reply: 160HP P-Pump limitations?
