1600-1750rpm Shudder/Rough Run
Old 09-15-2005, 11:50 PM
Buckshotmckee's Avatar
Question 1600-1750rpm Shudder/Rough Run
A question for you guys. Today I got home and for no particular reason ran the RPMs up to about 1600-1750 and notice the the truck ran real rough, kind of a shudder. After 1700 it cleared right up. Now in the past, since I got the truck I've noticed that in 1st gear moving along about the same RPM I get the same symptoms. Any thoughts????
Old 09-16-2005, 05:43 AM
storx's Avatar
sounds like the tq
Old 09-16-2005, 01:34 PM
phox_mulder's Avatar
Originally Posted by storx
sounds like the tq
No TQ on a 5 speed.
phox
Old 09-18-2005, 11:28 AM
neveragain's Avatar
poor running
Sounds like they haven't changed or improved the PDC and harness. MY guess is that it is a voltage spike corrupting the voltages from the vp-44. If you have access to a Fluke meter put it on frequency (HZ) I have seen HZ from 22 to 102. This is the problem.
Old 09-18-2005, 11:35 AM
If that's the problem, then whats the fix?
Old 09-20-2005, 08:56 AM
neveragain's Avatar
bad harness
Will have to find out where the harness is attached to rest of the wiring and do (REDO) cryslurrss typical poor quality work. Have had to do a lot on this 99junk so am not happy with it at all.
Does anyone know where the splices are from the PDC.???
Rafter B
04-13-2008 09:40 AM
wcialrlter
03-19-2006 03:07 PM
Push Rod
09-01-2004 07:42 AM
Gary C
02-21-2004 07:23 AM
Quick Reply: 1600-1750rpm Shudder/Rough Run
