150k On S-belt Think Its Time To Change Need Help
Old 02-19-2010, 09:13 PM
04600CTDRAM2500's Avatar
NOT SURE WHAT TO DO . Its so cramed in there .dont no where to start . Also think i should change tensioner, bought gatorback belt .i can not find a digram to help. seems easy but dont want mess it up. This a 04 5.9 w/ac
Old 02-19-2010, 09:54 PM
TexasCTD's Avatar
Here is a diagram of the belt routing. It's a good idea to replace the idler pulley and tensioner while you are at it. Hope this helps.
Old 02-19-2010, 10:14 PM
hi thanks looks like i might have too remove the fan shroud to get to the tensioner off any more info you might have would be great
Old 02-19-2010, 10:31 PM
With age comes the cage
Colo_River_Ram's Avatar
You can do it from the bottom without removing the shroud..
Old 02-20-2010, 08:30 AM
nedz19's Avatar
I had to replace mine at about 70000 and put new bearing in the idler pulley. Wasnt too bad took about an hour to do it all
Old 02-20-2010, 10:01 PM
s-belt help
I did it today took bit longer than i wanted but thankfully my neihbor came 2 talk then started to help one man job turned in to a 2 man job he pointed out y i was stuck . only thing is cant get a torq rench in to the tensor bolt to get the write torq to the bolt what should i do ?
Old 02-21-2010, 08:07 AM
RWDCelicadude's Avatar
Isn't it amazing how an extra set of eyes and hands can make a job go so much more smoothly.
Which bolt are you talking about? One that holds the tensioner to the engine? If so then I wouldn't worry about torqing it too precisely, just get it tight.
Old 02-21-2010, 08:27 AM
johnh's Avatar
that's funny..............tighten the bolt in a manner consistent with good workmanship..........all bolts don't need to be tightened with a torque wrench
Old 02-21-2010, 09:23 AM
Ace
Ace's Avatar
The list of ones that do is much shorter than the list of those that don't.
Justwannabeme
03-03-2011 11:27 PM
Chris Derrick
01-15-2010 04:51 AM
Chris Derrick
01-13-2010 03:46 PM
The Boss Hog
07-23-2009 05:22 PM
whereswaldo250
01-03-2007 09:51 PM
Quick Reply: 150k On S-belt Think Its Time To Change Need Help
