12v mods advice
Old 09-01-2011, 12:18 PM
97C-PowerPuller's Avatar
12v mods advice
With my 97 ctd truck, it is currently stock, besides replacing the clutch, putting stacks in, and refreshing the pump. I already have gauges, and so far 600$ to spend in mods. I want power to pull loads, plenty of torque, and plenty of smoke. What are the best free mods, and ones that will total at 600$?
Old 09-01-2011, 01:39 PM
TheNeckasaurus's Avatar
You said you already did the pump mods? If "refreshing the pump" means playing with the afc, starwheel,plate, etc then you've pretty much exhausted all the "free" performance mods.
Theres a plethora of designs for air intakes that will cost you under $100, take your pick.
You can always buy a plate, the cut is up to you. $30 ebay plates work just as well as the $220 ones. If you're going for performance Id say #0 plate. But I believe most guys who tow use a #10 or #100 but I could be wrong. What kind of clutch are you running? Is it a just a stock hp rated clutch? If so Id recommend getting a South bend or other higher hp rated clutch. Back to performance Id go with the plate, 3gsk or 4gsk, and remember if you go with the 4gsk you need the HD springs along with that. I believe with the HD springs its right around $220 for the 4gsk. Those things along with the pump mods are going to wake that puppy up. Then theres wastegating your turbo, bigger exhaust, DV's, injectors, turbos and the list goes on.
Some other guys who are much more knowledgable then myself will most likely chime in here but I think the intake $100, plate$30, 4gsk w/HD springs$226, wastegate$30, and say a 4"-5"straight piped exhaust$??? you'll come in under or around $600 depending on where and how cheap you can find piping. By the way, Welcome to DTR! For future reference and questions learn to use the search tool, instead of waiting for other guys to answer you might be asking the exact same question some other guy asked and BAM! Theres all your answers! Good luck man
Old 09-01-2011, 01:46 PM
yeah, thanks. I got the sb clutch, inject. pump was rebuilt to stock, am looking at 3k springs. I also have a bd super b turbo with 4 in back
Old 09-01-2011, 08:20 PM
SKATERHAULER's Avatar
Wish I could find an intake for a 100 !!!!
Old 09-01-2011, 09:38 PM
Lil Dog's Avatar
If they are meaning intake horns, save your money. Aren't worth the change to get them IMHO.. Your intake filter setup is just fine from the photos I have seen though I don't particularly care for brick filters and their ability to seal to the box.
Old 09-02-2011, 02:27 AM
13FOX's Avatar
How about you forget about making SMOKE!! and focus on good tuning. Smoke is cool at the track and pulling but not on the street!
Old 09-02-2011, 08:46 AM
What plate # do you recommend?
Old 09-02-2011, 10:03 AM
I was refering to an air intake, bhaf, scotty, etc. The homemade ones that do the same things as the $300 ones
Old 09-02-2011, 10:10 AM
Yeah i know. Like shaving it down, what #?
Old 09-02-2011, 10:15 AM
What is an intake filter ? Air filter ?
Old 09-02-2011, 11:08 AM
Well you said you'll be towing alot correct? And like I said before I think most the guys put #10 plates on their tow rigs. But I think it all comes to preference.
Old 09-02-2011, 11:19 AM
And where are these pics of your truck 97C?
Old 09-02-2011, 03:26 PM
Lil Dog's Avatar
You know what I goofed.. I was looking at Skaters truck and made the mistake of combining the two.
Old 09-02-2011, 03:32 PM
Thanks for the advice, im gonna go for a #10 plate
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
tristan21
06-19-2007 04:57 AM
DRM
06-30-2005 11:38 PM
imelmo
05-15-2005 02:04 AM
Quick Reply: 12v mods advice
