12v dino #'s
Old 08-15-2007, 01:30 PM
ajoebob's Avatar
12v dino #'s
what kind of dino #'s are you getting with your 12v's and how did you get it.
just getting ideas but only wount some that have done it not just saying it will work
thanks
Old 08-15-2007, 02:18 PM
dzlfarmboy's Avatar
Is yours a auto 180 pump or Stick 215 pump
97 180 auto Grounded #100 plate, AFC work, GSK washer Shimed, AFE, MBRP 5" Stock Timing....=280hp/685tq
98 215 Stick Grounded #10 Plate, AFC work, K&N, 3.5 Strait Pipe, Stock Timing....=313hp/Cant remember tq
2 customers trucks dynoed last weekend
Old 08-15-2007, 02:55 PM
ajoebob's Avatar
i have the 215 5 speed
Old 08-15-2007, 09:20 PM
cumminsdriver635's Avatar
I dyno'd 281hp/693tq with a 160 pump, 3k, 16* timing, and a 0 plate. Ill have new dyno numbers next weekend I have a dyno graph in my gallery
Eric
Old 08-16-2007, 07:43 AM
WideOpenThrottl's Avatar
A ways back I dyno'd, 325hp, with banks plate about midway, afc midway, 14cm housing with banks bighead wastegate, intake/exhaust, 16.5* timing and 3k gsk.
Tim.
Old 08-16-2007, 02:41 PM
blacksmokethis's Avatar
i dyno'd 356 hp/694 ft-lbs ,96 12 v ,180 pump, 330 injectors, 3k gsk, 0 plate full forward, star wheel full forward,17* timming, hx-40 , in fourth gear, south bend ofe, 4.10 gears, 315 toyo m/t's
Old 08-16-2007, 04:07 PM
ajoebob's Avatar
well it looks like everyone is hitting around 300hp+ -.
i have the 215 pump, 100 fuel plate and i was plaining on 370 injecters, 4gsk, htt 62/14(maybe twins). i am hoping to get around 450-500hp.am i to far off?
Old 08-16-2007, 04:10 PM
Jetpilot's Avatar
215 pump, 3k gsk, #10 plate, 191 DV's, PS62 turbo, F1 Hot Rod 370's, Timing set at 6.1mm = 531 RWHP.
Old 08-16-2007, 05:00 PM
drolex's Avatar
How much boost did that run? You guys are listing your mods but not the amount of boost. I would find the boost numbers interesting.
Old 08-16-2007, 05:17 PM
Dodge359's Avatar
See signature
Old 08-16-2007, 05:18 PM
Jetpilot's Avatar
Boost numbers are such an unimportant part of the equation. An example is I made 610 RWHP @ 42# on a VP truck, yet the above truck wa set to 45#..... Most guys tend to push too much boost and think they are getting a return on HP.
Doug
Old 08-16-2007, 05:33 PM
Ken in AZ's Avatar
I did 412rwhp in 5th gear with a 98 215 5spd with a #10 and a BHAF Timing @ 23.5 - everything else stock - popped the head gasket at that set-up so take that as you will
Old 08-16-2007, 05:53 PM
Dodge359's Avatar
Doug
Can I get an Amen
Old 08-16-2007, 06:02 PM
displacedtexan's Avatar
Originally Posted by Dodge359
Can I get an Amen
But I know a guy pushing 45psi on his stock turbo! Who cares if it is hot air, hurting his power, and risking blowing up his turbo, its more boost than I have
Old 08-16-2007, 06:17 PM
drolex's Avatar
Boost volume is important. You need the correct amount of air for the amount of fuel you dump. If you have too much fuel and not enough air and then you increase air you do get a return on HP. Different fuels provide different amounts of energy and require different amounts of oxygen.
Quick Reply: 12v dino #'s
