12 volt source for pyrometer
Old Mar 22, 2006 | 01:14 PM
440forPOWER's Avatar
Hello, I am looking for the best place to hook up the isopro pyrometer 12volt/ignition power wire. Does the fuse box have extra slots for accesories? Thanks
Old Mar 22, 2006 | 01:27 PM
rockjeep73's Avatar
There was an unused plug under my dash that had four female spade connections in one plastic bulkhead. One of the connections was a keyed 12v source, so I just plugged my gauges into it.
Old Mar 22, 2006 | 01:29 PM
Boatnik's Avatar
I just tapped into the radio power supply just down stream of the fuse panel. Works great.
Old Mar 22, 2006 | 01:34 PM
tboling's Avatar
Ya tapping into a fuse to the parking light or radio or other fuse's work just fine.
Old Mar 22, 2006 | 03:17 PM
ihpower's Avatar
I had an open hole in my fuse box
Old Mar 22, 2006 | 03:54 PM
andyr354's Avatar
There is the gray connector under the dash like mentioned above. This is the plug for the factory tach. I have it powering my tach and pyro. Also one of the leads in it it switched with the dash illumination.
Just need a spade and connect to it.
Old Mar 22, 2006 | 06:34 PM
I put a fuse tap under the power window fuse.
Old Mar 22, 2006 | 07:17 PM
ChrisLib's Avatar
I grabbed power off of the 12 wire at my unused tach plug
Old Mar 22, 2006 | 08:49 PM
WVU Dodge's Avatar
What would actually be the most right way to wire up something like that. Any time I ever wired anything up in a vehicle (cb, gages, whatever), i just wrap the bare wire around a fuse in the fuse block that is hot when i need it (ie. ignition, or acc.). I always considered this to be sort of unacceptable but that is the quickest and easiest. I know where everything goes but I always figured if somebody else was to look all the toys i got wired up would wonder what the hell I was thinking.
Should things like this in order to be done the "right" way have its own separate fuse, wiring, etc. Or is wrapping the hot wire around the radio fuse and shoving it back in the terminal considered acceptable. I'm not trying to knock anybody's wiring habits b/c I do the same thing and probably always will, just wondered if it is considered ameteur or not.
Old Mar 23, 2006 | 06:52 AM
triton0708's Avatar
WVU, that's how i was always doing it, the way my old man taught me. There are better ways, but this is simple, cheap, and most importantly, it gets the job done. Where abouts in Morgantown are you located? Always good to know another cummins nut in the same town...
Old Mar 23, 2006 | 03:49 PM
WVU, I wouldn't wrap the wire around a fuse. You can get fuse taps at Radio Shack for a more secure connection.
Old Mar 23, 2006 | 07:00 PM
Thanks guys, this is why I love this site. I think I will head down to radio shack and see if I can pick up one of those fuse taps. Thanks again
Old Mar 24, 2006 | 12:59 AM
AlK's Avatar
AlK
I used the lower side of the dash illuminating fuse. It is fuse 14 in the block on my 92.
Festus
Mar 2, 2011 01:00 AM
chuckybones
Jul 22, 2008 05:55 PM
essgeetee
Oct 25, 2007 12:29 PM
12valve@heart
Mar 7, 2005 12:19 AM
Dieseldude4x4
Jan 4, 2003 03:07 PM
