12 vavle head on sunnen surface mill
Old 09-01-2011, 08:26 PM
SKATERHAULER's Avatar
JUST DID MY HEAD @ A BUDDY'S SHOP ( FIGGA MACHINE SOUTH NJ ) IT TOOK 015 TO CLEAN UP . WENT TO CUMMNIS TODAY AND SPENT 269.00 FOR UPPER SET AND WAS TOLD TO GO WITH STANDARD THICKNESS , IS THAT THE CORRECT CHOICE FOR TAKING 015 OFF HEAD ?
Larry
Attached Thumbnails 12 vavle head on sunnen surface mill-dscn2138.jpg   12 vavle head on sunnen surface mill-dscn2139.jpg   12 vavle head on sunnen surface mill-dscn2143.jpg   12 vavle head on sunnen surface mill-dscn1835.jpg   12 vavle head on sunnen surface mill-dscn2144.jpg
Old 09-01-2011, 09:00 PM
Tate's Avatar
Since the head is flat, it won't change compression running a standard thickness gasket. It will change the valve depth and injector depth, which may cause piston-valve interference if running an after market cam or even the lash too tight. If you run a thicker gasket, you'll be dropping compression. Best thing to do would to have a valve job done so they are recessed further into the head. Then you would also have to adjust valve spring seat pressure, as it would decrease.
Old 09-01-2011, 09:03 PM
Thanks!! I decided not to touch valves , we removed and I had zero issues before head gasket started leaking . So if I install after I just shaved 015 off head with stock gaskit I will have bent valves ?
Old 09-01-2011, 09:06 PM
Tate's Avatar
I'm not saying you will, but your valves will now be .015" closer to the pistons than what they used to be. There should be .050" or so clearance between them when factory, so now you could be in the .035" range. Still clearance, but getting out of the comfortable range.
Old 09-01-2011, 09:10 PM
I want to keep it simple , should I take gaskit back and get 010 over to be safe ?
Old 09-01-2011, 09:40 PM
Lil Dog's Avatar
If your future plans include a cam, then yes a thicker gasket might be a good idea.
Old 09-01-2011, 09:54 PM
No cam , next step bigger turbo . Should I install the standard gasket ? Or go with 010 ?
Old 09-02-2011, 07:29 AM
patdaly's Avatar
I would not run the over gasket, personally I would have the valves sunk the additional .015 if I were too worried. I don't think you will have an issue.
Old 09-02-2011, 03:46 PM
thanks guy's!!! Spoke to Lenny @ DDP and asked him about 015 mill, he said for a street truck I'm OK with standard gaskit. Just took delivery of his stage 2 Inj and he said the supplied shim is fine for what I have . Anybody have a guess hw much HP I will have after stage 2 inj ?
SKATERHAULER
09-02-2011 10:57 PM
1985cucv
03-17-2009 02:37 PM
Hawthorne
12-11-2007 07:37 PM
West Coast
12-11-2007 04:11 PM
Dufrain
01-06-2005 12:03 AM
Quick Reply: 12 vavle head on sunnen surface mill
